Brake Light Switch
Old Jun 9, 2020 | 10:33 AM
joonman's Avatar
2008 ML350, 2011 S450
Brake Light Switch
Hi. I need to replace the Brake Light Switch. I am unable to find the location of this and a procedure on how to replace it. I found many instructions on the WEB, but not for W221. Thanks
Old Jun 9, 2020 | 06:14 PM
pmercury's Avatar
member
CL
hi, there is no procedure
just go down there and remove it
Old Jun 10, 2020 | 06:42 AM
joonman's Avatar
Thank you for the information. I guess I have to remove the plastic panel below the dashboard first to have access.
Old Jun 10, 2020 | 07:45 AM
pmercury's Avatar
member
CL
yes the last lower part might be enough
Old Jun 12, 2020 | 05:38 PM
joonman's Avatar
I change the brake light switch, but unfortunately I am having the same issue. My brake light is on all the time, even though the brake is not pressed. Also, car's push-button start will start the ignition without the brake being pressed. So, car is getting a signal that brake is pressed all the time. Any ideas as to what might be wrong? Thanks for your help.
Old Jun 13, 2020 | 11:20 AM
konigstiger's Avatar
'71 Pinto
Have someone pull fault codes using MB diagnostics.
Old Jun 17, 2020 | 03:41 PM
'71 Pinto
See attachments.
Old Jun 26, 2020 | 06:52 AM
joonman's Avatar
Thank you. At the end, it was the Brake Stop Light switch after all. When I installed first, I did not adjust the gray plastic piece that needs to be pressed closer to the brake pedal. Now everything is back to normal. No more permanent brake light constantly on, ESP light no longer comes on and Cruise Control is now functioning once again. All that trouble caused by one defective switch. Thank you for your help.
