TPMS QUESTION
Old Jun 18, 2020 | 11:55 AM
ChuckinTucson's Avatar
2012 S63, 2013 E350 Bluetec
TPMS QUESTION
I have a 2012 S63. The low tire pressure warning symbol is on the dash, but when I scroll over to check the actual tire pressure, it shows 37/37 front and 38/38 rear and the numbers are all in white (meaning they're fine). Anyone have an idea of why the symbol is still on even though the tire pressure is okay?
Old Jun 18, 2020 | 03:29 PM
kenstudios's Avatar
Try reset. Press arrow down to reset then ok. If reset doesn't work then it might be a bad sensor
Old Jun 18, 2020 | 05:17 PM
COUPCONNOISSEUR's Avatar
2010 CL550
is it possible one or more batteries could be going bad??
Old Jun 19, 2020 | 01:09 AM
The Thomas J's Avatar
2010 MB S550, 2017 MB SLC 300
Yes.
It's also recommended to use plastic covers on the air valves. Metal covers shorten the sensor's life.
Old Jun 21, 2020 | 06:43 PM
Good suggestion, but they're both fairly new. The aux is less than a month old.
Old Jun 22, 2020 | 09:41 AM
DaleB's Avatar
Veteran: Army
2007 S600
Have you checked the pressure in the spare?
Old Aug 9, 2020 | 07:47 PM
rmetzner49's Avatar
2009 CLK350 Cabriolet with 18" AMG Fitment TSW Rims
TPMS
@TheThomasJ
Yes.
Is that to suggest the transmit antenna lives in the stem? Otherwise that doesn't pass the sniff test. Can you point to a link that confirms your theory?
Bob M.
Old Aug 9, 2020 | 07:58 PM
whoover's Avatar
'19 E63S sedan
Originally Posted by rmetzner49
@TheThomasJ
Bob M.
TPMS stems are metal. A metal cap sets up galvanic action that can cause bimetallic corrosion and damage the valve. The current produced is small but it can also interfere with the sensor. This is why TPMS stems never come with metal caps and their use is strongly discouraged. You might get away with it in California, but an area that uses salt in the winter will cause the stems to corrode very quickly if they're capped with a different metal.
https://www.autoserviceprofessional....-compatibility
Old Aug 10, 2020 | 10:03 AM
BOTUS's Avatar
S500
if the desired pressure setting (was manually set) very high and you are now a long way from it you'll get a warning....
level them up and press reset
mine doesn't have one on the spare
Old Aug 12, 2020 | 01:10 AM
Yes, that's exactly why. I learned the hard way on my former Toyota 4runner that had metal caps on the valve stems. Thank you for answering and saving me the time of doing so. I run chrome wheels in the summer and use matching chrome caps on the valve stem. In the winter, I switch to alloy wheels and use plastic caps.
Old Aug 12, 2020 | 01:09 PM
lkchris's Avatar
'10 CL550, '12 GL550
@TheThomasJ
Bob M.
oh yes, and the valve cores are nickel rather than the previous brass to avoid corrosion. Don’t replace them with pep boys junk.
