belt/bearing chirp and squeal
Old Jun 24, 2020 | 09:04 PM
Will Hunt's Avatar
2008 s550
08 s550 had a belt squeal for first few minutes of driving I replaced the belt tensioner and it reduced to a chirp thats constant. The belt and idler pulleys were replaced 8 months ago can't seem to locate it.
Old Jun 25, 2020 | 11:41 AM
dlafever's Avatar
'15 S550, '10 E350 P1/P2, '02 ML320
That squeal could be a bearing on one of the belt-driven components. You might try removing the belt and slowly rotating the Alternator, Water pump, etc. by hand. A mechanics stethoscope can help isolate the source of the noise.
Old Jun 26, 2020 | 11:38 PM
zoto's Avatar
W221 S350 2006 + Porsche 997.2
If you don't have a stethoscope try a short length of 13mm black poly retic pipe - works a treat; just be real careful not to get it caught up in the belt.
Speaking from experience another reason may be due to the belt and in particular the side of the belt rubbing against one of the pulleys - try rubbing a dry cake of soap on the side (again be very very careful) and see if it stops for a while. And in my case using a non genuine MB belt caused the problem - disappeared when I went genuine belt.
Old Jun 27, 2020 | 07:18 AM
Will Hunt's Avatar
2008 s550
I have a cheap belt from O'Riley's but I just ordered a gates belt.
Old Apr 21, 2021 | 12:27 AM
bbbc78's Avatar
04' S600
As a note. I got the lube from that service bulletin and the noise goes away for the day but comes back in the morning like clockwork.
