2012 S550 4matic front air suspension PLEASE HELP!!!
2012 S550 4matic
I hit a pothole and my right front air suspension would raise and keep lowering this wentvin for about 3 weeks. One morning I came out side and the front end was low on both sides. I just replace the right air suspension, air suspension compressor and compressor relay. The car still won't raise. I I checked lines. They seem to be good. I'm at a loss.
2007 SL550 & 2012 S550 4matic
You need MB star DAS XENTRY to tell you the root cause of this failure. Several parts could have been damaged in the pot hole incident. Have you tried a soap water solution on air connection spots? Try some on the top of strut and then use switches in console to raise the car. It might be a simple leak or new struts or something in between.
Received 4,435 Likes
'71 Pinto
