Indy shop shocker
Like I said, these are mostly little things. I know the suspension issue needs attention before I start blowing ABC lines, so that's about the most urgent. The coolant thing is a major annoyance, but as noted it never happens when driving -- only when it sits overnight AFTER having been driven.
After a week I got a call from the mechanic with their quote to sort out everything. It was (I swear I’m not making this up) $14,319.86. Fourteen grand and change. I had to laugh. I picked up the car, paid them for a couple hours of shop labor to do the diagnosis, and went through their estimate line by line. It's bloody astonishing. The markup on parts alone would be a few thousand of that number, and over half is for work that doesn't even need to be done.
I broke down the stuff on my blog (see it here), and will keep it updated as I do the work that is needed. Saturday my son and I knocked out the rear brakes, at a total cost of $188 (including shipping and tax) and three hours of our time. I've got parts coming in this week to do most of the rest, and a service bay with a lift reserved for this coming weekend.
I'd gladly pay a shop to do the work... if I could find one locally that I could trust to do it without trying to bill $14K for what I would reasonably expect to pay about $3K-$4K for. Hell, over $4K of this estimate was to replace the coil packs and plugs -- which I just did a couple of months ago, and which are working just fine, thanks very much. $1,036 markup on those parts alone.
So this weekend I'll replace both ABC accumulators and the pulsation damper. I can't see any leaks anywhere near the pump, but hey -- maybe that's what he was looking for when he either disconnected or broke my washer pump. It hasn't lost any ABC fluid in the past six months or so, so it if it leaking it's not too bad yet. Rear brakes are done. I'm arranging to have another shop replace the A/C suction line (78% markup they had on that part, BTW) that's the probable cause of the A/C issue; we'll leave the compressor (57% markup) alone for now.
Probably the least of the problems I'm chasing, so if I can get it fixed, great -- if not, I'll put up with it.
The charge for labor actually seems low compared to what is charged near me.
Awesome cars, and I'm not sorry I bought it (though I would have gone a different route with the benefit of hindsight). It's worth the hassle. If I were not able to work on it myself... probably not so much.
So far, all work has been done by myself with some friendly help and I have the SDS, but I can see where this car could get stupid expensive from what I hear and what I read here. Just the other day, my dynamic seat decided to no longer function. Checked it with Star. Yessir, module likely defective. I haven't dug any deeper but what could have happened in the last week? It sat in the garage most of the time!
Air lines crack
Rubber degrades and leaks
Air compressors seize up
Mice, squirrels, gremlins, elves, fairies, poltergeists, leprechauns...
Shop estimate to repair cooling system: $3281.23
Parts cost: $7.88
Tools & Materials: $101
Shop time (service bay rental): $120.00
Total spent: $228.88
Total Saved: $3,052.35
And that includes the , which I'll no doubt use many more times. The full story is http://dale.botkin.org/2020/08/16/cooling-system/ (blog post).
I also did most of the ABC work today, but it isn't quite finished so I'll post more about that later.
Last edited by DaleB; Aug 15, 2020 at 11:58 PM. Reason: Corrected service bay cost, 3 hours @ $40/hr
Parts cost: $7.88
And that includes the cooling system fill/test kit, which I'll no doubt use many more times. The full story is here (blog post).
The vacuum tester will tell you if you HAVE a leak, but not where it is.
Just an example. I took my F150 to an oil change place for an oil change a couple of times. For $70 they put in non-synthetic oil and a cheap oil filter, and it took maybe 10 minutes tops. I can do a complete oil change at home for about half that, but using full synthetic and a premium oil filter -- and I'm buying retail. The shop wanted to charge just barely under $250 for an oil change. For an oil change. Really? I mean, come on. I take pride in my vehicles. I do not take pride in bragging about how much I pay to keep them running. "If you have to ask, you can't afford it" is one of the dumbest things I've ever heard. In my humble opinion, if you don't ask, you're not too bright.
OK, end of rant.
There are lots of ways to learn this stuff. Friends or relatives are a good way. YouTube videos CAN be... of course any idiot can post anything to YT, and a lot of idiots do. But if you look through this forum, you'll see a number of posts by user @39039 that are really good examples of how to do basic preventive and even corrective maintenance yourself. These cars are generally not at all difficult to work on -- no more so than any other, and certainly less than many. Of the three vehicles I own, the S600 is hands down the easiest one to do an oil change. I changed out the ABS accumulators yesterday. As part of that I had to remove the driver side exhaust. Horrible job, right? No, not at all. Half a dozen bolts (NONE of which were seized or rusted solid) and everything just came right out, and went back in just as easily. It really is a great car to work on.
Totally agree with you on self maintenance. I ran into couple issues with works from dealership: a V8 engine oil filter on a V12 (no filtering for >5000 miles); missing brake lid cap after brake flush service (discovered after 3month so it needs another flush). If you don't look at it once in a while you will just never know.
It is unfortunate the shop tried to take advantage of you. And the work you do yourself is always the better quality.
I did have that nice cold drink, though. I felt I'd earned it.
While working on the car, though, I did notice that the front brakes were worn well beyond where the rears were. I could maybe get another few thousand miles on them, but not many -- and we're about to start a 2-3K mile road trip. I picked up new rotors and Akebono Euro pads today, I'll swap out the front brakes tomorrow after work when I finish up the ABC and put everything back together. Then we'll see if my fuel injector work pays off or what. Cylinder 9 has been consistently the problem child. I pulled the #8 and #9 injectors, but as I don't have a test rig there wasn't much I could do. I ran them both in a ultrasonic cleaner for about 20 minutes and put them back in swapped around. One of three things will happen...
1.) The whole problem goes away, I'm happy, and it was just a dirty injector.
2.) The problem moves to cylinder #8, and I know for certain that I have one bad injector.
3.) The problem remains with cylinder #9, and I know for certain I have a bad coil pack, which is still under warranty.
Now I wish I'd thought to swap the plugs between #9 and #10, just to eliminate those as well. I suppose it's possible for a new spark plug to be bad, though I haven't seen it happen in about <mumble mumble> years of driving and maintaining cars, motorcycles, lawn implements, and the occasional airplane.
The front brakes rotors were badly worn. The pads were actually in great shape, with lots of material left. It didn't LOOK like it when I inspected, because there was such a big ridge around the edge of the rotor that it covered up about half the pad thickness. Apparently, the last time the car was serviced (by a M-B dealer, no less) they replaced the pads but not the rotors. Not the route I would have taken at all. I mean, these things were pretty badly worn. But, now I've got fresh brakes all around, and hopefully no more dense black brake dust everywhere from the semi-metallic pads. Total cost: $167.75 for parts, and I guess you could include $40 or so for the service bay rental since I did it there.
Total saved on ABC: I guess it depends on your point of view. I didn't replace the pump, and won't unless it gets much worse. Shop quoted $3612 for everything. I spent a total of $717, including the service bay rental and five liters of fluid that I actually ended up not even opening. I'll use it for the next ABC system flush. But to be fair, subtract what they were going to charge for the pump. Basically, I think I saved about $250 worth of markup they would have added onto the parts, plus 7.5 hours labor.
The one outrageous charge from a local dealer was $200 for labor to replace the starter battery under the hood of my car in addition to the cost of the battery. I drove one block away and called Mercedes roadside assistance. They sent out a mechanic from the same dealer with a battery and installed it with no labor charge, only the same retail price quoted at the dealer. Roadside assistance is free if you are the original owner of your vehicle, but for newer vehicles it is free only during the 4 year new car vehicle warranty.
