Why some have and some don’t?
Old Aug 23, 2020 | 03:56 PM
MB CHS's Avatar
S550
Wonderful afternoon everyone, I tried researching these pins but not even google has the answer. Does anyone know what these three pins are for?
Old Aug 24, 2020 | 10:09 PM
MBENZTECH's Avatar
W203 W212 W211 R53MCS
Only an experienced person can tell you.....So........That is where the solenoid for wet clutch control plugs into.
Old Aug 25, 2020 | 12:00 AM
MB CHS's Avatar
S550
Effin A I came to the right place thanks for the response. I have those three pins but don’t understand the whole wet clutch concept if you don’t mind can you explain what it does, what I’m supposed to plug in there etc.
Old Aug 25, 2020 | 08:56 AM
konigstiger's Avatar
'71 Pinto
Not experienced , see AMG SpeedShift here: https://en.wikipedia.org/wiki/Mercedes-Benz_7G-Tronic_transmission in your S550 there should be a cap at this location.
Old Apr 17, 2022 | 11:38 AM
MB CHS's Avatar
S550
Help with size of bolt
hey guys, I need your help with the size of this bolt. When my alternator was installed they messed with this bolt, now it’s leaking oil and the car won’t start. Any info on this bolt will be greatly appreciated.
Old Apr 18, 2022 | 12:17 PM
Long2757's Avatar
2007 S550 AMG Sport
Seeing how it's been 1.5 years since this thread was started and this is a different issue, I would make a new thread. I am not familiar with that bolt or why an oil leak would prevent the car from starting.
Old Apr 19, 2022 | 01:57 AM
Minh's Avatar
S350 2008
This is a timing chain tensioner bold, if you remove it by accident then either you need to replace it or reset it before to re-install, if you just re-install then it will make timing chain over tension therefore it easy to damage
Old Apr 19, 2022 | 07:21 PM
MB CHS's Avatar
S550
how do you reset it? Because mine was loose and I just tightened it but now you got me scared to restart the engine??
