W221 CAN bus thread
Old Oct 14, 2020 | 02:18 PM
ClasseMiaMadra's Avatar
2016 S212
Subscribed
It sound like Chris the Swede should be invited to this thread. He seems to have done a lot of work on the w221 AND in adding features to the Android screens he sells so his input would make this thread even more interesting. Possibly he can add features to-order ? In a recent DIY install the Autovlog guy did (of youtube AMG hydrolock fame) showed engine performance metrics as android apps (I think).
Old Oct 14, 2020 | 02:25 PM
Hatzenbach's Avatar
2009 W221
Originally Posted by ClasseMiaMadra
Subscribed
Good idea, but maybe better in a separate thread
Old Oct 14, 2020 | 02:28 PM
2016 S212
I actually emailed his contact address at his site, cmkdesigns.
Old Oct 14, 2020 | 02:47 PM
DaleB's Avatar
Veteran: Army
2007 S600
I dunno, he'd be a welcome addition here if he's willing to share any of his knowledge of the CANbus stuff. Especially things that could save time like (for instance) message specifics.
Old Oct 16, 2020 | 01:24 AM
blackmambo90's Avatar
W221 s550, W211 e320 cdi
Hi again,
My project is moving forward, and now i am at a stade where i will be picking up some can messages from the black can bus. Not sure witch one that is (The telematics CAN?), but it is the one that have the joystick and those buttons on left of the screen.
While i am there, i can pick you up some of them. Witch one are you wishing? The one to disable parktronik?
Old Oct 16, 2020 | 10:02 AM
Hatzenbach's Avatar
2009 W221
Originally Posted by blackmambo90
Hi again,
That would be awesome!
Yes, the codes for Parktronic ON/OFF, and - of course - we also would need to know in which pair of twisted wires you tapped into.
And the CAN bus speed (I believe not all are 500 kbps)
Many thanks!
Old Oct 16, 2020 | 12:43 PM
  #32
DaleB's Avatar
Veteran: Army
2007 S600
Hi again,
Ideally, the messages for the Park Assist button pressed and released, AND the messages to turn the LED in that button on and off would be helpful.
If I had my way, I'd replace that red LED with a green one, and turn it on (green) to indicate PA is enabled, instead of red to indicate disabled. If I retire early and have enough spare time on my hands it would be a nice weekend project... but honestly given the rate with which other stuff on this car is breaking, I don't know that I'd ever get to it., The damn heater didn't work when I drove it today, now that temperatures are down in the 40s. grumblegrumble.... more parts to replace.
Old Oct 17, 2020 | 04:10 PM
  #33
Hey, it look like this button is not on this can bus 🤔
i will plug to the second one (the one that i will plug the video in motion filter) and i will see if it is there later. Maybe tomorrow or next week
Old Oct 17, 2020 | 06:24 PM
  #34
Hatzenbach's Avatar
2009 W221
OK, I had some time this afternoon, so I decided I do some CAN bus sniffing.
My equipment: A MCP2515 "shield" that connects to the CAN bus and sends the data to an Arduino via SPI
The Ardunio is connected to a laptop via USB and sends the data on the COM bus to a freeware app that reads and displays the data.
And - positive surprise - after i opened the access panel I found out that all the twisted wires with the same color are connected to each other, well that makes it much easier
So I start with the yellow bus, I get good readings and lots of data, but don't find the signal I'm looking for
Next the green bus, same result
(My search algorithm is that I press the button repeatedly and look for data that changes the same time I press the button)
OK, that leaves us with the brown bus: I attach my probes to the brown bus and something strange happens:
Every time I connect my probes, the bus "collapses". It goes so far that the lights in the footwell go out.
I first thought that my probes created a short circuit on the CAN bus but, no they are fine.
Next troubleshooting step is to pull the terminator resistor, no change, same problem.
Looks like when I attach the MCP2515 to the brown CAN bus it just doesn't like it.
Any ideas? Wrong CAN bus speed?
Old Oct 17, 2020 | 08:14 PM
  #35
Yes, that what a wrong speed can do
try 125 000
Also there is more than 3 can network on this vehicle, so it may be that you will not find it, how ever i do guess that is suppose to be the yellow one...
Old Oct 17, 2020 | 09:22 PM
  #36
Hatzenbach's Avatar
2009 W221
try 125 000
Thanks, I'll try that.
where would i find the other CAN bus(es)?
Old Oct 18, 2020 | 04:00 PM
  #37
Hatzenbach's Avatar
2009 W221
try 125 000
Good news: after changing the speed to 125kbps I could read the brown bus
Bad news: The signal which I'm looking for is not on the brown bus either (and I also double-checked the yellow and green buses again - nada)
Throwing in the towel...
Old Oct 18, 2020 | 06:41 PM
  #38
megacrazy's Avatar
CLK55 W209, CL63 W216
The problem is more complicated than you guys are assuming. Hint to advance the project: the switch sits on LIN B3
connects to N72/1 which sits on can B aka interior can which goes to the CGW.
Old Oct 18, 2020 | 06:57 PM
  #39
Hatzenbach's Avatar
2009 W221
thanks but not enough hints for me
Unfortunately I’m way more familiar with the inner workings of Porsches
Old Oct 18, 2020 | 07:12 PM
  #40
megacrazy's Avatar
N72/1 is the climate control stack in the center console. The park assist button connects to that via LIN bus. The center climate control switch sits on CAN B. So the switch itself has no connection to the can bus.
Old Oct 18, 2020 | 07:18 PM
  #41
Hatzenbach's Avatar
2009 W221
got it (hmmmmmm, at least I believe I got it ;-)
But am I assuming right that when I push the button, that this will create an event on the interior CAN bus B?
Old Oct 18, 2020 | 07:19 PM
  #42
megacrazy's Avatar
Absolutely it should. So don’t throw in the towel yet
Old Oct 18, 2020 | 08:44 PM
  #43
DaleB's Avatar
Veteran: Army
2007 S600
Yeah... the switch itself isn’t doing squat, it’s just an input to a controller. The switch state is read by a control unit, which (eventually) causes a message to be placed on the CAN bus. I suspect that message is not “someone pressed the PA button”... probably the controller is monitoring the state of the users input, controlling the LED via LIN (bummer if that’s the case), and sending “Turn PA on/off” messages on the CAN bus. But... there are numerous ways to do it, and I could well be totally wrong. Just need to dig in and see.
I don’t have the CAN bus interface I ordered yet, and won’t for at least a couple of weeks I suspect. Sigh. In the mean time I can work on getting my stupid heater to work, grumble grumble.
Old Oct 18, 2020 | 09:28 PM
  #44
Hatzenbach's Avatar
2009 W221
I am assuming that in order to get to the interior CAN-B I need to take off the panel with the A/C vents (the one which goes across the whole dash)?
If yes does anyone have anymore pointers what I'm looking for then?
Old Oct 18, 2020 | 10:26 PM
  #45
megacrazy's Avatar
Or tap at one of the can distribution blocks. It’s brown and brown red wiring as far as I remember.
Old Oct 18, 2020 | 10:47 PM
  #46
Hatzenbach's Avatar
2009 W221
but you don't mean the one from the first picture?
Old Oct 19, 2020 | 08:50 AM
  #47
megacrazy's Avatar
That should be the one. If that doesn’t work for you, you can always look at tackling the Lin bus. 1 wire to tap behind the button. Similar approach to can bus with some differences.
Old Oct 19, 2020 | 09:53 AM
  #48
Hatzenbach's Avatar
2009 W221
If that's the case then I'm afraid that we went full circle, see my post #38
Picking up the towel from the floor and throwing it in again ;-)
Old Oct 19, 2020 | 08:19 PM
  #49
megacrazy's Avatar
The signal is definitely on a bus. Pack your towel away and go back to the garage for more scanning
I am assuming you had the car running - obvious but you never know.
Old Oct 19, 2020 | 08:52 PM
  #50
Hatzenbach's Avatar
2009 W221
Yeah, car was running, otherwise you can't operate the switch
But of course the disadvantage of a running car is the abundance of CAN messages, vs. when only the ignition is on.
I also think that the brown/red bus is the internal bus, because - according to the documentation - the internal bus runs on 125kbps and that's the only bus (that I found) on that speed.
BUT here's another thought
Are CAN gateways separating the same CAN bus into segments so only allow certain numbers of different CAN signals are on that part of the bus.
If that makes sense, maybe there's another location where I can tap into a different segment of the internal bus?
Just a stupid thought.
