Mercedes S W221 Abs Problem
Old Dec 22, 2020 | 11:55 AM
ProBgd's Avatar
Mercedes-Benz CLS63 2012 700hp
Wink Mercedes S W221 Abs Problem
Today i start the car drive 5 km and abs light came
Steering is hard,parktronic not working bilnd spot ...
Fault code 5909 control unit n47-5 internal fault
Old Dec 23, 2020 | 07:13 AM
BOTUS's Avatar
S500
doesn't sound good
the steering going hard, will be as its impacted by the faulty speed information it receives via the ABS system (for the variable assistance)
not sure which n47-5 is if that's the ABS module then its could be a very standard ABS fault common to many manufacturers - oddly more rare on a Mercedes than most others
intriguingly two different units with different failure mode?
CL-Class ABS pump and module malfunction will cause fault codes to be stored for 5944 – ESP control unit internal fault, this will illuminate the ABS warning light and prevent the full operation of the emergency braking system.
CL-63 AMG this ABS from the Mercedes CL is a common failing component causing the abs light to illuminate when plugged in to diagnostics you may find fault code 5066 – Power Supply A7/3M1 High Pressure Return Pump, 5001 – Control Unit N30/4 (Electronic Stability Program Control Unit) Internal Fault or faults for wheel speed sensors or in some occasions you may find you are unable to communicate with the control unit.
Old Dec 23, 2020 | 07:18 AM
BOTUS's Avatar
S500
a very common issue is the brushes in the motor that provides brake pressure for the ESP get dirty and stick causing the motor to misbehave... some times a few light taps with a wooden block will temporarily help and make the light go out....
lots of fun on BMS with this very fault - on the BMW R1200GS you can pull it apart and swap to a ford fiesta brush pack that's far better made !!!
Old Dec 23, 2020 | 08:07 AM
BOTUS's Avatar
S500
according to one post..... N47-5 ESP Computer Module
https://mbworld.org/forums/s-class-w...n47-5-fix.html
Old Dec 24, 2020 | 02:41 AM
Minh's Avatar
S350 2008
It's problem in the PCB of the ESP control module, I have sent it to electronic shop for repair as well, they open a plastic cover of the ESP module do did something on the circuit print board and it's very quick fix,
Old Dec 24, 2020 | 07:51 AM
BOTUS's Avatar
S500
that's the post just above yours...
designed in failure mode !
Old Dec 25, 2020 | 04:12 AM
Elbalt's Avatar
S550
most likely your abs sensors are bad or you have a loose connection with the abs sensor in the front wheels.
