parasitic battery drain (again)
Old Apr 10, 2021 | 02:21 PM
Hatzenbach's Avatar
2009 W221
Happy Saturday,
I'm fighting a parasitic battery drain on my car (again)
I went through all the usual troubleshooting steps, but my problem is slightly different: one module randomly turns on and off over time.
Below you see a chart of battery draw over ~18 hours.
As you can see the draw is not constant
I did several of these samples and one thing is always the same:
  • When it's dark outside I have an average draw of less than 20 mA (which it should be)
  • During the day it randomly jumps to 3.3 - 3.4 A for 20 - 30 seconds (it's always the same draw, so I think it must be the same module)
What module could be triggered to turn on only by daylight?
One more hint: sometimes I see the red LEDs on the two temperature adjusters blinking when the car is parked.
Old Apr 10, 2021 | 10:41 PM
bmwpowere36m3's Avatar
'11 E350, '11 E550, '98 M3, '95 E320
I haven't tried a W221, but Xentry can display network activity on the CAN/s. Depending on the chassis, the level of information varies... but it useful nothing the less to narrow down what module is waking up.
Old Apr 11, 2021 | 05:37 PM
EasyPhil's Avatar
2007 S550 4Matic 2013 S550 Base
Try covering parts of the top of the car to narrow it down.
Old Apr 11, 2021 | 08:55 PM
Will Hunt's Avatar
2008 s550
Try unplugging the tele-aid module.
Old Apr 19, 2021 | 03:38 PM
Hatzenbach's Avatar
2009 W221
I am looking for some ideas how to find this parasitic drain
What I know that many times in a 24h period *something* in the car gets activated and then draws 3.3 - 3.4 Amp for 20-40 seconds.
Naturally this is very hard to troubleshoot
I tried some reverse engineering: I tested the current across each fuse using an "AmpHound" to see if there is anything that draws this kind of current.
And it turns out that the fuel pump draws exactly this current.
So I pulled the fuse for the fuel pump and did a long time test again, unfortunately I still have the same occasional parasitic draw.
And by now I'm pretty much out of ideas...
Old Apr 19, 2021 | 08:06 PM
Jason B's Avatar
W140 Mercedes S350, W221 S550 sport
I can fix this issue for you. I'm a dealer for AntiGravity batteries and it's awesome and lithium ion and sites at a resting voltage of 13.1 volts. Has bluetooth to monitor everything and weekly reports. I've sold these to my Ferrari and Lambo customers as those cars suck for draw, horrible. This will fix the issue. If you're thinking about this let me know and I'll help you out.
Old Apr 19, 2021 | 09:14 PM
Find an indy with Xentry or go to dealer... the latter will so have have additional tools to data log can bus activity if needed. Otherwise continue to pull fuses, one each night... If you really want to go crazy, instead of measuring total draw at the battery. Measure it across each circuit (fuse) and log it over a 24 hrs period. That'll help narrow it down... at the expense of TIME.
Old May 11, 2021 | 10:28 PM
Hatzenbach's Avatar
2009 W221
Thank you, that fixed it!
Old May 11, 2021 | 10:37 PM
DaleB's Avatar
Veteran: Army
2007 S600
Interesting. I was just looking at something the other day about using Xentry to disable Tele-Aid completely. I thought at the time it wasn't a bad idea, it's of utterly no use to me (or anyone else, I'm sure). I wonder if doing that would prevent the module from powering itself on, or not.
Old May 11, 2021 | 11:43 PM
Hatzenbach's Avatar
2009 W221
and i should probably add that me measuring the battery draw over 24h (see first post) was apparently a red herring.
I still have the same pattern but now the car still starts after 5 days (before the tele-aid module was pulled) the battery was dead on day #3
I also bought and installed an Antigravity Batteries AG-BTR-1 Battery Tracker, which allows me to check the battery voltage from remote, very convenient. (My car is parked on the street, it doesn't fit in the garage)
Old May 12, 2021 | 01:39 AM
EasyPhil's Avatar
You could use Xentry to update the Tel-Aid module to mBrace.
Old May 12, 2021 | 08:12 AM
DaleB's Avatar
Veteran: Army
2007 S600
Even if I could, I can think of no conceivable reason I'd want to do that. It won't even remotely start the car.
Old May 12, 2021 | 11:04 AM
EasyPhil's Avatar
True it won't remote start the car but the car locator and remote door locking and unlocking work.
Old May 12, 2021 | 03:12 PM
DaleB's Avatar
Veteran: Army
2007 S600
Color me very unimpressed. In over four decades of driving I have never yet lost a vehicle. Remote lock and unlock? If I forget to lock the car, I'm not going to remember until I get back to it. And you can't really lock your keys in one of these. Mine won't lock the doors if there's a key inside, and won't latch the trunk if there's a key in there, either. We figured that out the first time we tried to leave my wife's purse in teh car when we were at some event or other -- she had to take her key out of her purse before we could close the trunk.
Like Night Vision, it's a gimmick with very little or no practical value. I wouldn't need or use it if it were free, and it's far from it. I pay quite a bit less for AAA than Mbrace would cost, and it's actually occasionally useful. So I think I'll pass, thanks.
Old May 12, 2021 | 07:51 PM
megacrazy's Avatar
CLK55 W209, CL63 W216
Interesting that’s the first time I hear this. Have you done it? Any tips/insight?
Old May 13, 2021 | 08:33 AM
EasyPhil's Avatar
Yes, I did a couple of years ago. It's a straight forward update. I signed up for the mBrace trial after the update and then cancelled
Old May 14, 2021 | 09:45 AM
megacrazy's Avatar
Interesting. I will check it out next time I hook my car up.
Old Dec 3, 2022 | 08:19 AM
m32's Avatar
m32
996tt
OP, were you able to isolate and resolve this drain? I’m looking to purchase a 09 s550’ from a friend but the car also has a parasitic drain.
Edwin
Old Dec 3, 2022 | 09:35 AM
Hatzenbach's Avatar
2009 W221
Edwin
no I was never able to completely pinpoint it and ended up selling the car.
Old Dec 3, 2022 | 12:26 PM
BOTUS's Avatar
S500
the rain light sensor stays awake as it can close the windows and sunroof on its own... it would also see changes as the light level alters... its a mad module the OCP programming turns the car inside out and upsets everything
after the original pre facelift cars were made - Merc started on a journey of special extras magically built in software.... likely to ensure you struggle or stay within the dealer network burning money for fun
