W221 Serpentine belt diagram
Old Apr 20, 2025 | 03:08 PM
Arrie's Avatar
Originally Posted by kevm14
Couple things.
1) We have to remember that there are like 3 belt configurations for these cars, and that's just for V8s. M273 07-09 which has a conventional power steering pump. On the facelift 2010 and 2011 cars (US market, still M273), the steering is self-contained electrohydraulic with no external P/S pump. And then there are the M278 cars from 2012-2013 which I assume continue to use that self-contained electrohydraulic steering system.
2) The location in that diagram is used on the X166 for the hydraulic antiroll system (active curve control I believe it was called). There may well be another application where there is a pump there that is used for power steering but not on the W221.
This is a bit confusing as I could not find the steering system in the WIS/ASRA that came with BenzNinja system.
Also, my 2010 E550 has conventional power steering pump. I just replaced it a couple weeks ago but this 2012 S550 does not have a pump driven by the serpentine belt.
Is it then electronically driven pump that I have? There certainly is a reservoir for the fluid so there must be some sort of a pump I would think...?
Old Apr 20, 2025 | 03:11 PM
kevm14's Avatar
04 E55 AMG (totaled), 07 S550 4Matic, 14 E63S
As I said, 2010-2013 W221 uses a self contained electrohydraulic power steering system. The pump is electric.
My 2014 E63 uses full electric power steering. I don't know when the W212 switched or if it was in that big 2014 facelift.
Old Apr 20, 2025 | 03:16 PM
Arrie's Avatar
Thanks for the info. I need to have a look at some point so to know what/where it is as it will need help sooner or later. I have no issues at the moment but with an old car you never know when it hits...
Old Apr 20, 2025 | 03:21 PM
kevm14's Avatar
https://mbworld.org/forums/s-class-w...ml#post7578685
Old Apr 21, 2025 | 01:46 PM
Arrie's Avatar
Thanks a lot. The link to the thread shows exactly what I must have with the small reservoir running to other end of the steering.
The pdfs have info mixed between cars with 273 and 278 engines though but that is fine...
