W221 Serpentine belt diagram
Went and changed the belt, belt tensioner and two pulleys. Missed one as I did not know it had three of them so need to order one more. I changed pulleys 6 and 7 in the picture below. Pulley 8 has a bigger Torx end bolt on it so I wonder how to order that one?
But, as I did the job I looked for the power steering pump and could not locate one.
My engine looks like in picture below. The 4b location does not have any kind of a pump in it. It is just a big pulley and I think it is place for the ABC pump for cars that have that system.
Thought it is electric power steering but there is a small reservoir in right side of the engine bay in front of the engine coolant reservoir. A hose from it runs to the bottom of the engine bay, across and then disappears under the A/C compressor.
Can anybody shed light to this as where is the pump and if electric, why reservoir...?
Decoding my VIN does not say anything about power steering.
1) We have to remember that there are like 3 belt configurations for these cars, and that's just for V8s. M273 07-09 which has a conventional power steering pump. On the facelift 2010 and 2011 cars (US market, still M273), the steering is self-contained electrohydraulic with no external P/S pump. And then there are the M278 cars from 2012-2013 which I assume continue to use that self-contained electrohydraulic steering system.
2) The location in that diagram is used on the X166 for the hydraulic antiroll system (active curve control I believe it was called). There may well be another application where there is a pump there that is used for power steering but not on the W221.
