Coding the downstream O2 sensors 2006 S600
Old May 13, 2021 | 02:29 PM
jarvarix's Avatar
w221 S600
Hi. I was wondering if anyone could help me out with this.
I've tried with the star, but I can't find the list of numbered components that Robert AMG referred to in a post about this many years ago.
So I'm wondering if my car has old software installed or my star is the problem.
it says at the startup of DAS that it's a developer open version.
and I can change a lot of parameters in the menu. But can't find the O2 sensors.
anybody knows what to do?
Old May 14, 2021 | 08:06 AM
BOTUS's Avatar
S500
coding ?
they just work....
Old May 14, 2021 | 08:09 AM
jarvarix's Avatar
w221 S600
Originally Posted by BOTUS
coding ?
they just work....
Yes, i know. I want to code them off. Since the cats are not on the car anymore. 😊
Old May 14, 2021 | 08:40 PM
MBENZTECH's Avatar
W203 W212 W211 R53MCS
You can not code them off completely. You can turn off diagnostics of rear O2 sensors. You still need to have them plugged in. You can completely remove it by flash tuning, in this case you don't have to have them installed.
Old May 15, 2021 | 03:58 AM
jarvarix's Avatar
w221 S600
That's what i was thinking of. But im not sure where to do this, since i don't get this list of components with numbers.
I'm going thru all the steps in the star, and after implizite kodierung, i get a list. But not sure what to do to turn off diagnostic.
Old May 18, 2021 | 05:05 AM
Minh's Avatar
S350 2008
Hope it help
https://mbworld.org/forums/cl-class-...at-delete.html
Old May 18, 2021 | 01:35 PM
jarvarix's Avatar
w221 S600
Originally Posted by Minh
The list you see in this thread, is not the same list i get.
So that's my problem, my list in the Star menu only display names. But will check if there is any lambda controll there.
Some of the names is listed in German, when my star is set to English. 🙈
Old May 19, 2021 | 11:12 AM
BOTUS's Avatar
S500
same with most German vehicles, by the time you delve in to settings you shouldn't, you often come across words in German. It is after all the native language of the manufacturer
Old May 20, 2021 | 04:54 AM
Minh's Avatar
S350 2008
It the same principle, you will get all menu in German language when you enter adaptation data for tuning option ON/OFF
Old May 22, 2021 | 11:02 AM
jarvarix's Avatar
w221 S600
Finaly figured it out. It's called lambdaregelung tvz1 in the menu on my car. Test drive done and no faults. 👌👌
Old Jun 18, 2021 | 02:07 PM
jarvarix's Avatar
w221 S600
And I've also coded them out as well.
Now listed as not fitted.
