2011 S550 front compartment noise over speed bumps
Old Nov 29, 2021 | 02:50 PM
sepehrkz's Avatar
2029 S560
Hey guys,
I have this noise problem with my when I go over even the smallest bumps at no matter what speed it makes this terrible noise.
I took my car to my mechanic, they said everything looks fine.
However, they glued up all the suspension parts together and the noise still exists.
Please check out the attached video to hear the noise.
I'd be very thankful if you can help me figure out what's causing this problem and how to get it fixed.
Old Nov 29, 2021 | 04:03 PM
konigstiger's Avatar
'71 Pinto
If they have not already done so other things to consider, suggest checking tie rods see attached bulletins and torsion bar linkage & bushings.
File Type: pdf
File Type: pdf
Old Nov 29, 2021 | 09:03 PM
Senecat's Avatar
1983 Nissan Shltbox
If you're mechanic is using glue on your suspension, you need to fire him immediately.
And what kind of mechanic only visually inspects and doesn't drive the vehicle while diagnosing? Obviously the problem still exists, regardless of what he saw with his eyes. What a scam. What the hell is the world coming to? Your mechanic is obviously wrong, and what he did didn't solve ****, so take the damn car back and make him fix it.
I'd have your issue ID'd over the first bump if I were behind the wheel. It's definitely a suspension component/s, most probably those indicated in konigster's post.
Old Nov 29, 2021 | 09:17 PM
kevm14's Avatar
04 E55 AMG (totaled), 07 S550 4Matic, 14 E63S
The glue thing was a legit repair, albeit bizarre. I just read about it today. Front anti-roll bar bushing/carrier to subframe.
Old Nov 30, 2021 | 06:30 AM
tbilisi79's Avatar
Check front control arms and ball joints. Often Strut bar bushings will get weak.
Old Nov 30, 2021 | 09:14 AM
Senecat's Avatar
1983 Nissan Shltbox
No, it's not legit. It's BS. I don't care what you read.
Put the car in the air and start pry-barring.
Old Nov 30, 2021 | 10:00 AM
kevm14's Avatar
why TSB say to glue sway bar bushing, instead of replacing - MBWorld.org Forums
It's legit in the sense that this is the OEM approved way to fix this particular issue. You can talk to me all day long about how you don't agree with it, and that's fine.
Old Nov 30, 2021 | 10:52 AM
MBCO's Avatar
2015 SL550 & 2012 S550 4matic
Have mechanic check lower control arms. My W221 exhibited same creaking sounds. Replaced with new OEM part to solve the issue.
Old Dec 1, 2021 | 07:33 AM
mcb66's Avatar
clk320
Also check sway bar bushing/ brackets. I had one of the bolts break off on a bracket.. Made the same noise.
Old Dec 1, 2021 | 09:33 AM
Minh's Avatar
S350 2008
damage on sway bar or control arm can be visual. Since the car checked by shop already therefore I believed no issue with sway and control arm.
Noise likely cause by strut: inside strut there are a rubber mount on top a strut and it broken over the time then it can't mount hydraulic suspension and make so much noise over speed bumps. Since this rubber mount is inside the strut then you can't visual check until you disassemble entire strut. (See video for detail)
File Type: mov
Old Jan 18, 2022 | 06:50 PM
2014CL600's Avatar
Cars
Are you still having the issue? It's usually the front struts that are bad. If you take one or both out you will find that they have been leaking on the top of the strut. I just placed mine on my CLS550 and even Mercedes told me everything was OK. I kept taking it back until one mechanic told me it was a bad RH front strut. I changed it and half of my problem went away, I changed the other side and now all of the noise is gone. Just because your strut stays up doesn't mean it is working properly. I bought my struts from a dealer at a very deeply discounted price and had each installed for 100.00 a side. It took all about an hour for each side and now, it's quiet as a church mouse.
Old Jan 18, 2022 | 06:51 PM
2014CL600's Avatar
Cars
I found this to be the case years ago on a Jaguar XJR and then again on my CLS550. Everyone overlooks this and so, here we are.
Old Jan 18, 2022 | 07:47 PM
The Thomas J's Avatar
2010 MB S550, 2017 MB SLC 300
I am 99% certain it's a control arm and ball joint. The S Class is a very heavy car. The control arms and ball joints wear out on these cars every 45,000 to 65,000 miles. I had both sides done within a year of each other under warranty at the dealer.
Old Jan 19, 2022 | 07:04 AM
kevm14's Avatar
So you're saying they used E-class suspension on the S-class?
