Center console lid
Old Dec 18, 2021 | 03:39 PM
natcahd's Avatar
Veteran: Air Force
2023 S580 (Current) 2011 S550
Center console lid
I had an upholsterer re-cover the center console lid. The faux leather was getting loose. He did a good job with the cover, but after inspection it only opens to the driver side. Looks like he may have put it back together incorrectly. Maybe this is why two other upholsterers wouldn't touch it. He is ordering another lid. Anyone else run into this problem?
Hd
Old Dec 19, 2021 | 03:10 AM
conmee's Avatar
2013 S550
I thought it was real leather. I've seen DIY instructions that involve a heat gun to heat up the leather then using a cold wet cloth to cool down and tighten the leather back up. How'd the reupholster job come out, lid functionality nothwithstanding?
Old Dec 19, 2021 | 08:35 PM
Senecat's Avatar
1983 Nissan Shltbox
Good job. Post pics.
Old Dec 20, 2021 | 06:29 PM
natcahd's Avatar
Veteran: Air Force
Old Dec 20, 2021 | 06:31 PM
natcahd's Avatar
Veteran: Air Force
When you see the larger pics ...doesn't look as good as I thought..lol
Hd
Old Dec 21, 2021 | 10:15 AM
doni01's Avatar
2013 S550 4MATIC
Hd
It is sad that the oem's become all sloppy with time because those are done perfect. But yours doesn't look bad.
Old Dec 21, 2021 | 04:40 PM
natcahd's Avatar
Veteran: Air Force
doni,
Hd
Old Dec 22, 2021 | 10:32 AM
megacrazy's Avatar
CLK55 W209, CL63 W216
Considering that the lid is not meant to be disassembled and is glued together, I think it came out pretty good. The mechanism in it is pretty fragile and gets brittle over time so it could either be broken from age (or slamming shut) or maybe they assembled it incorrectly. I would just deal with it.
Old Dec 22, 2021 | 10:39 AM
natcahd's Avatar
Veteran: Air Force
Mega
I am guessing one of the components/springs moved during reassembly.
Hd
Old Dec 25, 2021 | 03:04 PM
Senecat's Avatar
1983 Nissan Shltbox
Looks awesome.
Old Jan 6, 2022 | 05:59 AM
Senecat's Avatar
1983 Nissan Shltbox
Hey OP, was that a local guy or did you send your lid out? I want to get mine done. I'd even mail it to your guy. I think yours looks better than factory. The microscopic stitching flaws say "bespoke" to me, I really like that. It's a personal touch.
Old Jan 22, 2022 | 10:58 PM
natcahd's Avatar
Veteran: Air Force
Senecat,,, I would hold off for now. He is local. We have been looking for another lid that works correctly and cover that one. He feels bad that he somehow made armrest inoperative. I have a question could the below part be the problem?
A2218703958 SWITCH , A 26557620081001809
Koenig u there? Hope i didn't misspell the name.
Old Jan 24, 2022 | 05:06 PM
bajaleo's Avatar
2009 S63
See if anything in this thread helps. Konigstiger provided me with some documentation that helped me with my problem.
https://mbworld.org/forums/s-class-w...p-section.html
Old Jan 24, 2022 | 07:26 PM
natcahd's Avatar
Veteran: Air Force
Bajaleo...I will try tomorrow but i have a side opening not front upwards.
Old Jan 25, 2022 | 09:27 AM
bajaleo's Avatar
2009 S63
Are you sure? I thought all 221's had a center console lid that opened from either driver's or passenger's side, and also from the front to reveal the bigger storage area. In my car, the button to open the lower is visible just beneath the upper button.
Old Jan 25, 2022 | 12:28 PM
natcahd's Avatar
Veteran: Air Force
Bajaleo,,I only have one set of buttons. One on each side with no tray on the inside. It can be opened from either driver or passenger. Well it is supposed to be that way (not right now though). Driver side button can be depressed but not passenger side. I am really thinking its a mechanical problem. I sprayed WD-40 on the pins front and back to no avail.
KONIG and others help!!
Old Jan 25, 2022 | 12:35 PM
konigstiger's Avatar
'71 Pinto
Check CLS docs posted here (your mechanism should be the same): https://mbworld.org/forums/s-class-w...ml#post8061695
Old Jan 25, 2022 | 01:02 PM
natcahd's Avatar
Veteran: Air Force
konig...Thank you...same info given by Baja. I know my lid does not open front upwards, so no use going to rear ac area. I will fiddle with the settings in your .pdfs.
Thanks again.
Old Jan 25, 2022 | 01:49 PM
'71 Pinto
Unfortunately, no such docs for 221 or least I have not been able to find one.
