Bluetooth parring.
Old Apr 14, 2022 | 03:44 PM
Timo Schroeder's Avatar
Class S 500 M278
Bluetooth parring.
Bluetooth parring - S 500 2012.
How in h...... Can I get my phone connected to the comand ? I can search for available phones and find my phone - but the comand asking for a code - I have absolutely no clue what cowhat
The standard code for US doesn't work there in Europe, either the pin code for the phone.
Can someone please help ?
​​​​​SOLVED ! It was actually pretty easy after all - just read what your phone writes. Exactly as SUPERSWISS - posted.
Old Apr 14, 2022 | 04:31 PM
Groundhog101's Avatar
GLS550
Have you tried 62872 by any chance?
Old Apr 14, 2022 | 04:33 PM
Class S 500 M278
Yes - it's the standard code for US, but unfortunately not in the European Union
Old Apr 14, 2022 | 04:34 PM
superswiss's Avatar
2019 C63CS
During Bluetooth pairing there's a code generated by one of the devices and needs to be entered on the other device. Newer systems just generate the code and ask you to verify it that they are the same on both devices. Below is an example of what you might see during the pairing request. The phone or COMAND generates and displays the code, and that code has to be entered on the other device to authorize the pairing. It's a random code. Every time you pair with another device a new code gets generated. For certain devices if there is no code then 0000 is the default code. For example if you pair with a keyboard or a mouse that don't have any means to generate and display a code.
Old Apr 14, 2022 | 04:41 PM
superswiss's Avatar
2019 C63CS
Oh, I just checked the owner's manual. It's old school early Bluetooth version for your generation. You pick the code yourself. Just enter any code in COMAND and then your phone should ask for the code and you enter the same code as described. It just makes sure you are pairing with the intended device by entering the same code on both sides. Take note that some phones may only work with 4 digit codes and other phones support codes with more digits.
Old Apr 15, 2022 | 01:06 PM
Diesel Benz's Avatar
Actually for all those devices (bluetooth HF profile adapters) that need a code, it is "MBUSA" / "62872" also in Europe.
The one in question is more difficult as any code will work as explained above.
Old Apr 15, 2022 | 05:36 PM
lkchris's Avatar
'10 CL550, '12 GL550
Just to clarify ...
This is pairing for telephony only.
Pairing for music from your phone did not exist in 2012 ... bluetooth to airbuds came with IPhone 6 in 2016.
Old Apr 15, 2022 | 05:39 PM
Class S 500 M278
And it worked perfectly - thanks for your reply. Happy Easter.
Old Apr 16, 2022 | 05:22 AM
BOTUS's Avatar
S500
funny when you read the user manual applicable to your car it helps
have a great Easter :-)
Old Apr 16, 2022 | 07:07 AM
Class S 500 M278
Not quite in this matter.
Old May 11, 2022 | 08:14 AM
JohnPerchun's Avatar
f30
Hello! I recently became the owner of the w221.
I plan to buy a head unit on Android OS, but before that, I want to study in detail all the aspects, difficulties, and possible consequences of such an undertaking.
I have a 2013 model.
Maybe someone already installed it, please share your experience, I will be very grateful.
Many THX)
Old May 11, 2022 | 01:38 PM
BOTUS's Avatar
S500
yes - there is a long thread on android units
Old May 12, 2022 | 03:11 PM
jmirgy's Avatar
Silver 2013 S500 AMG. 4.7 litre V8 Bi Turbo 7 Speed Gearbox
I have a 2013 S550 and recently had a LIMCET unit installed for me. It sits behind the CD unit and comes with all the relevant cables and plugs and effectively sits between the MB system and the speakers. It pairs with both CarPlay and Android. I now have full CarPlay and with a single push of one of the console buttons can switch between COMMAND and CarPlay. My car play is controlled by my COMMAND button and everything is seamless. I paid 1,000 dirhams, about $370 Australian for supply and installation. I am very happy with the system. Good Luck.
