diy rear level sensor bracket
I shortened the U-bolt threads slightly - they were close (but not touching) the parking brake actuator with the anti roll bar at full droop.
This is the bracket installed on the anti roll bar (sway bar!) - the 10mm ball is in exactly the same place as the original:
I used the new connecting rod from the Mercedes clip. If I were to do it again I would use an M6 threaded ball stud and make it all from stainless.
Hope this might be useful
Pete
in the end used a stainless worm drive hose clip to hold the standard bracket on, after the garage trashed the second new one trying to fit it - only thing is the std one has some cushioning / flex built in its design I guess to send less NVH up the arm
Pete
I go with the idiot who designed it having to fit all replacements - but I'd hope we can all so ensure none of his genetic material lives on
I have rigged it together with a couple of cable ties, but really like your design.
Where did you get the bracket from, do you have a link to the parts?
Thanks for your help, and good work!
Hope this helps.
