Continuous warning that I have exceeded the speed limit 120 km/h in the box. Why is
RTFM
in the cluster stuff u aren't supposed to know about, I think they buried another iteration of this in there and some taxi driver BS - and user memories for temp units, temps set points alongside the seat and mirrors - or do the first two actually work anyway? but if so why 4 memories when they only give three to play with ? I think it was a step in play they never bothered with?
coding level - the standard setting Geschwindigkeitsbegrenzung aus - Speed limit off
I'm guessing a sick joke for markets where drivers aren't allowed to think for themselves - like USA and Japan
there is a level in Xentry that lets you get further - most main dealers have this OFF as they don't train garages on the fact it exists let alone how to use it - developer mode - is a deeper level - but you can wreck the car - this is really a tool used during "development" aka build of the car by the engineers making them.
there are people that flash mix and match files at the cluster - likely discovered when hacking the mileage - but its risky and I don't know anyone that adds the features - and the early cars have limited storage to write larger files without it going pop
the best way to get much more support and can help with lots of stuff - benzninja knows lots about mercedes and how to use all the features of the software packages that can get at these vehicles - you need to re-invest in your software package
dealer level (temps speed units and not much else)
developer level, add this toy or that option, but the choices available are hardware and of course software dependant
what seems to go wrong is the saving and rebooting so it wakes up using the changes can be inconsistent
but of course that's not it for everything - lots of feature like more involved displays of fuel consumption, a coffee cup, high beam assist etc.all came with far later builds and higher option levels
my thoughts why you can't have all those by just ticking a box
the gateway would need to be able to understand what it is and where to send it,
the data actually needs to exist - and this is linked to features inside modules of later cars, which comes from hardware, software and sensor changes of any relevant modules or indeed more modules, cameras, etc.
the brain of the cluster would have to be big enough to programme and even then the hardware must able to cope (and the early ones were a bit naff)
