Engine Control Module / Unit (ECM / ECU) Replacement
Has anyone ever had a problem with their ECU and if so has anyone been able to order a replacement part from Precision ECU or any other company and had successful results? I’d love to know if there are any cheaper options and if anyone in Chicago area knows a place that are knowledgeable to do ECU work.
At this point in his life, my father no longer drives and only likes to be driven in this vehicle so that’s why my siblings and I want to get it fixed however just upsetting it’s so expensive and strange why the sealed electronics failed like this when the vehicle is hardly used and when used it’s driven gently.
not that anyone posted the original warranty fix PDF in this recent link but some idea of the issue here - https://mbworld.org/forums/s-class-w...to-wiring.html
stock
https://www.obd2shop.co.uk/wholesale...-computer.html
playtime
https://www.obd2shop.co.uk/wholesale...tag-v7020.html
Models 164, 171, 203, 204, 207, 209, 211, 212, 216, 219, 221, 230, 251, 463
Engines 272 and 273, MY 2005 – 2011 Camshaft Adjustment Solenoids - due to the settling properties of the seal, oil may leak from the camshaft adjustment solenoid dealers will retrofit four adapter harnesses onto the engine wiring harness. Covers any/all repairs due to damage from oil leak however, notes replacement of leaking camshaft solenoid is not permitted under consequential damage.
Approximately 557,108 vehicles are affected. Have dealer check VMI to determine if vehicle is included. Service Campaigns are covered out of warranty.
