Center Grille
Old Feb 11, 2023 | 01:31 PM
Arrie's Avatar
Center Grille
I am in need to replace the low grille in front under the bumper. It is called "Center Grille" or something like that.
I ordered a new part but my question is if anybody here in the forum knows if I need to remove the bumper for replacing it.
Old Feb 11, 2023 | 02:40 PM
konigstiger's Avatar
'71 Pinto
Check your email.
Old Feb 11, 2023 | 06:42 PM
Shadly1's Avatar
2007 S550
I've done it. I did not take off the bumper. It was a pretty easy job.
Old Feb 11, 2023 | 11:46 PM
Arrie's Avatar
Check your email.
Thanks konigstiger!!
Old Feb 11, 2023 | 11:48 PM
Arrie's Avatar
Thanks Shadly1. I sure hope it does not require bumper removal. I will find out…
Old Feb 12, 2023 | 10:31 AM
nath_h's Avatar
2008 CL550, 2022 EQB 300, 2023 EQS 450 4Matic
It's a very easy job...definitely no bumper removal.
Old Feb 12, 2023 | 11:29 AM
red996's Avatar
2013 W221 S550 2016 C217 S550
I replaced mine from below...I didn't take off the bumper.
Old Feb 12, 2023 | 12:21 PM
Arrie's Avatar
Thanks guys,
I feel good about doing this job now. I’ll let you all know how it goes when I get to do it after part arrives and I have time to do it.
Old Feb 12, 2023 | 03:34 PM
red996's Avatar
Seems after a couple of years, or if you get a big rock hit, you will be doing this again. You'll get good at it. Lol.
Old Feb 12, 2023 | 03:48 PM
Shadly1's Avatar
2007 S550
I always seem to hit truck tire chunks. 90% of the damage to my car is from junk that comes off of trucks on the highway.
Old Feb 12, 2023 | 03:57 PM
red996's Avatar
I was searching for a "metal" after market substitute for this. You could do one of the diy grills I guess. Probably wouldn't look right....
Old Feb 12, 2023 | 04:34 PM
Arrie's Avatar
Yeah, it very easily could happen, just is that the car had this hole when I got it. The previous 2013 model I had for 1 1/2 years did not have problems and I was able to dodge all debris on road. I started using the Distronic at max distance on highways after too many windshield replacements...also helps with debris on road that can be difficult to avoid if following too close.
