2011 Mercedes S550 - M278 main (crankshaft) bearings
Old Mar 19, 2023 | 06:15 AM
4r8en's Avatar
2011 Mercedes-Benz CL500 4matic
I'm doing a rebuild of the M278 and can't find main bearings, the only one I found are chinese - SINOCMP and ULTRA POWER.
While I know there are no OEM main bearings, are there any from respectable manufacturers?
Old Mar 19, 2023 | 06:22 AM
chassis's Avatar
2017 GLE350 4MATIC
Calling
@arsupisemnet
Old Mar 20, 2023 | 12:35 PM
arsupisemnet's Avatar
2014 GL450, 1992 W140 300SD, 1993 W140 300SE, 1987 E30 Convertible
There is only MB main bearings for M278, you can substitute with previous generation engine from OEM vendors, however the lock on the last bearing in M278 is cut on other side to prevent it, so either you cut new key hole in block and cap, or punch new lock in replacement bearing
Old Mar 20, 2023 | 12:37 PM
E55Greasemonkey's Avatar
This place is a joke.
Are they discountinued or just on backorder?
Old Mar 20, 2023 | 12:40 PM
They are not discontinued, just replaced serial numbers, his WIS/EPC is outdated
Old Mar 20, 2023 | 12:42 PM
Either way it might not work with OEM bearings because of two reasons - both block and crankshaft in stock option has deviation in diameter, that is why it has color coding in crankshaft and stamps on engine block. (color corresponds to different diameter) OEM substitution only works when you had to regrind crank (since no MB repair sizes available) and line hone engine block.
Old Mar 24, 2023 | 12:54 PM
4r8en's Avatar
So what's the best solution for old block and new crankshaft? Original MB bearings or chinese substitute or modifying bearings from other MB engine?
Sorry, English is not my first language and sometimes I don't quite understand the details, hence my questions.
Old Mar 25, 2023 | 11:20 PM
Best solution is to go through WIS and identify marking for upper half on block and lower half on crankshaft pulley shaft and buy accordingly to color coding from MB.
Old Mar 29, 2023 | 02:20 PM
4r8en's Avatar
@arsupisemnet thank You! You're my savior
Old Aug 10, 2023 | 01:28 AM
AZKwok's Avatar
GL550
Main bearing color coded
What’s WIS and how can I identify the bearing for my engine? My original bearing has two colors 2 gold and two green ( blue?). How can I find which color bearing go to which? Please help?
Old Aug 10, 2023 | 10:46 AM
AZKwok's Avatar
GL550
Could you please help identify the upper bearing color coded for my block with the original crank?
Thanks in advance,
