2008 S550 Headlight adjustment woes
Any help gratefully received
Nick
if pointing at the floor its usually a sign the level sensor is lying - the suspension level sensors seize and or snap off all the time on the w221 models
the lights if not molested / or broken can never go out of alignment ...so in general alignment should never ever be touched
if one is different to the other and no one has molested the car, likely a headlamp has broken inside, so don't touch the alignment
if the headlights don't follow the nodding indexing procedure at first switch on - they or a level sensor is misbehaving - thus never touch the alignment
bit of a theme there - stop touching the alignment its normally never the issue - but if you touch it you just made it another part of the mess
if some idiot moved the wrong, of course they'd be wrong and you might need to put them back to standard - or indeed some child played with ride height to make it drive worse, which could again mess things up
