Red battery light after working in trunk
Then I went to start the car this morning and had a red battery light on the dash. I checked voltage at the underhood battery and found that it's only 12.7V with the car running. Seems to be that my alternator suddenly isn't charging. I did not even see the rear battery (not sure exactly where it is, actually). Is it possible that something being unplugged (or inadvertently broken??) in the rear could be causing the issue? The previous owner replaced the rear battery. Even then, that shouldn't cause the low 12.7V with the car running. My thinking is that it has to be the alternator, but it's strange that would happen immediately after unplugging things in the trunk. I just want to make sure there isn't some weird subtlety with the M-B system before I spend $400 and several hours replacing the alternator.
Thanks.
Do you have any codes?
There is a ground cable in the spare wheel well (if memory serves me) on the right. Very obvious. Maybe it's loose?
Know that the front battery is the "Starter Battery" and the rear battery is the "Electrical System Battery" (about 50% larger than the starter battery). Here are the part numbers on the receipts for my car. I bought them at RBM in Atlanta (big MB dealer):
- "Starter Battery": 001-982-82-08, $265 (now it's $310: https://mbparts.mbusa.com/oem-parts/...ttery-19828208 )
- "Starter Battery": 001-982-79-08, $374 (now it's 396: https://mbparts.mbusa.com/oem-parts/...ery-1982790826 )
I'm not deeply familiar with how these batteries share work in the car, but my guess is that the starter battery is only used to start the car and the other battery is used to power all of the electronics in the car.
My dealer will match the prices on the official MB Parts website: https://mbparts.mbusa.com I suspect yours will too, if you ask. If they don't want to give you the MB internet price, simply get the part number you need from the parts department, order it online from MB and pick it up at that very same local MB parts counter, hahaha...seriously.
If either battery does need to be replaced, you don't have to go with the expensive Mercedes ones. The accessory battery is an H8 AGM battery. They sell them at Walmart for about $180. The starter battery is an oddball size. I upgraded mine to a larger, more common group size so I could use another AGM battery. They tend to last longer than flooded batteries in really hot climates. Your battery tray in the engine compartment has hold downs for multiple sizes of batteries.
Keep us posted.
on some merc models they design it so the thicker brown earth wire snaps like a carrot due to movement of the boot lid
I expect the red light is a separate fault
quite interestingly - red light on the dash is normally on the facelift where something goes odd - still waiting to hear the complete cure for that one
Here's what I found when I went in there. I couldn't believe it:
I was gearing up to either solder or crimp the wires and repair them. It would have been a bear for me being that I don't have a lot of experience with such. Then I had the bright idea to ask a stereo shop if they would do it. For around $35 (+ tip) they did a job better than I ever would have. Very professional and did it in 30 minutes while I had a coffee next door.
mod 1) cut the hidden trim bit to provide a smooth arc not a nasty stress point
mod 2) remove 9 pointless cable ties, so I could free up the spare 6" of loom to better route and follow the smother arc I created
