Electrical issue
Now everything is pretty much happening together, I have a snap on scanner that is giving me a bunch of can bus codes and I couldn’t communicate with the sam modules front or rear.
It seems to be worse when it is hot outside. I let the car sit for a week and the weather cooled down for a couple of days(70s) and everything seemed to work properly, now it is getting warmer again (90s) it is happening again and getting harder to start.
I’m just trying to get a step in the rite direction of where I should be looking, thanks for any info
the flat bit you see with fuses is not really the SAM, underneath in that bucket amongst the rats nest of wires from hell is a module that might have fried its brain due to water ingress - they are not just plug and play - but if you get the same part number and or one of multitudes of later ones you will get a starting point to play from
the other issue is the batteries, (if the front is a baby one you likely have a huge one everyone ignores hidden in the boot - but a real 2008 should just get a huge one upfront...) these cars can't diagnose faults without the battery going flat doing the tests - they must have battery support whilst working on them
check for water - delete all the codes it just holds tonnes of lies due to low voltage and historical confusion - get the battery / batteries in A1 condition, add a charger and start again...
https://www.mercedesmedic.com/merced...gram-location/
if anyone connected a battery back to front, the pre fuse boxes need checking out
But then again, I am just guessing.
Let us know your running voltage.
I'd pull up the front passenger side floor mat - it folds back from the firewall to unveil a load of kit on the can bus on an aluminum plate their feet rest upon - check for soggy connections under here (beneath the battery it fills with leaf litter then fills the car up inside)
canbus faults on mercs with a soggy unnoticed puddle beneath the front passenger carpet cause many mercs to give up - they do it on purpose to get older car's off the road
disconnect the batteries before playing fully....
canbus works on silly low voltages and pathetic signals, so even the slightest corrosion sends madness around the car
to the right (if LHD car) of the fan blower motor sits the HVAC module this might be damp too...
spend ages disconnecting all multiplugs in and around this area and remake a few times to clean up the connections and use something like ACF50 to help abate corrosion
you really need to check for leaf litter under the front battery.... ALL the the rain off the roof and screen drops there and floods the blower motor and under your carpet - take a look at the primordial swamp at both side of the screen drains (that never worked from new)
https://mbworld.org/forums/s-class-w...ml#post8820643
I was just watching a M5 crash repair where the car wouldn't start due to a pyro-fuse blowing as all the airbags had deployed. This cuts the power to the engine deliberately. Thinking about your car and the point you just made (about it starting if sitting in the wrong seat) I can image the weight sensor on the drivers side has failed... its embedded in the hideously expensive seat cover that includes the seat foam....
My car scans for the seat weight sensor module when I use my Autel scanner then jumps passed - as my age euro spec cars don't have this feature. But interestingly when I fitted a new seat cover (as the heated seat failed) I bought a passenger cover from a LHD car for my RHD drivers seat. This had the sensor and wiring for the weight sensor and I have a spare plug on the seat module it would fit too - but deliberately didn't connect as it might just upset things (on my car), - I guess you could likely code out the weight sensor feature with the autel scanner or xentry and re connect that plug ?
As for worrying about the airbag and how it might go off in a crash - we should all worry - takata - basically made airbags worldwide for all cars and went bust a few years back - after struggling with the costs of about 7 million recalls to replace airbags that explode and shrapnel kills the driver and passengers - and with many dodgy governments doing deals with car manufacturers its leaving all the old cars with deadly airbags
Australia just won a case after taking Mercedes to court for deliberately trying to cover up which cars needed the work
https://www.accc.gov.au/media-releas...pulsory-recall
https://recall.mercedes-benz.com.au/
Out of all those codes, the one that would worry me the most is "no voltage to electronic ignition switch". Almost all of your modules need a signal from that in order to power up.
Some Deoxit D5 and a nylon bristle brush will do wonders for your corrosion. You can also spray it directly into unplugged connectors to clean them up.
