Throttle lag? Code it out
Old Jan 4, 2024 | 05:18 PM
kevm14's Avatar
04 E55 AMG (totaled), 07 S550 4Matic, 14 E63S
Drove it a little more today.
That characteristic Mercedes soft initial tip in is still there, which means the throttle is not ridiculously jumpy or something. But once you get through that tip in, it's very responsive. Basically if you want it smooth, just be gentle with it and there is no issue. As soon as you need some torque, just press a little more and it goes. All you could ask for, really.
Old Jan 5, 2024 | 01:16 PM
vettebk's Avatar
2007 S600, 2007 Chrysler 300 SRT8, 2000 C5 Corvette, 2017 Mustang GT, 2023 300C, and a 2019 Lincoln
I think these lists are fabulous. I never would have deciphered this stuff. BOTUS you have everything on here except the Gefiltefish setting. Many thanks.
Old Jan 6, 2024 | 07:24 AM
BOTUS's Avatar
S500
Originally Posted by BOTUS
gone acronym-tastic today - all the experts have LOADS missing, this is the small Merc list........
here we go did a bit more tidying
MERC Technical Acronyms English
4MATIC 4 Wheel Drive / All Wheel Drive
A/C Air Conditioning - Automatic - Tempmatic
AAC Automatic Air Conditioning
AAM All Activity Module
AAV Activated Carbon Valve (emissions)
AB Supplemental Restraint System (Airbag)
ABC Active body control
ABS Antilock Brake System
ACS Automatic clutch system
ACSR R Automatic Child Seat Recognition
ADM Automatic Dimming Inside Rearview Mirror
ADS Automatic Damping System (suspension)
AFA RB Roll Bar Control
AHE Trailer recognition
AHV Trailer coupling
AIR Secondary Air Injection
AKB Activated Carbon Container (emissions)
AKR Anti-Knock Regulation
AP Accelerator Pedal
APS Auto pilot system
AS Antenna System
ASC Acceleration Skid Control
ASD Automatic Locking Differential
ASR Anti Slip Regulation / Acceleration Skid Control
AT Automatic Transmission
ATA Anti-theft alarm system
BA Backup Assist
BARO Barometric Pressure
BAS Brake Assist System
BCAP PC Barometric Pressure-charge Air Pressure Compensation
BDC Bottom Dead Center
BM Base Module (Master Ecu Controller)
BNS Vehicle Power Supply Control Module
BOU Brake Operating Unit
BPC Barometric Pressure Compensation
CA Closing Assist
CAN Controller Area Network
CC Cruise Control (Tempomat)
CCM Combination Control Module
CDC Cd Changer
CGW Central Gateway (ZGM on BMW)
CF Convenience Feature
CFI Continuous Fuel Injection
CKA Crank Angle
CKP Crankshaft Position
CL Central Locking
CLUS Instrument Cluster
CMP Camshaft Position
CNS Communication and Navigation System
COU Comand Knob (ZBE)
CPS Crankshaft Position Sensor
CST Cabriolet Soft Top
CTEL Cellular Telephone with UHI
CTP Closed Throttle Position (Idle)
CTU Central Triggering Unit
CV Convertible soft top
CVN Calibration Verification Number (coding)
DAS Driver Authorization System
DBE Real Name for the OCP (roof module)
DCM-FL Door Control Module Front Left
DCM-FR Door Control Module Front Right
DCM-RL Door Control Module Rear Left
DCM-RR Door Control Module Rear Right
DFI Electronic Distributor-type Fuel Injection
DI Distributor Ignition System
DM (USA) Diagnostic Module (Emissions)
DM Diagnostic Module (Emissions)
DPM Diesel Particulate Matter ?
Dr SAM Drivers side SAM (Signal Acquisition Module - ROW-Body Control Module)
DS-LF Dynamic Seat - Left Front
DS-RF Dynamic Seat - Right Front
DSP Pneumatic Pump for Dynamic Seats
DTC Diagnostic Trouble Code
DTR Distronic (Main Radar)
DZA Speed Increase with Engine Load
EA Electronic Accelerator
EAG Electronic automatic transmission control (Auto transmission)
EAM Extended activity module (As of model year 2000)
EATC Electronic Automatic Transmission Control
EBP Electronic Brake Proportioning
EBR Electronic Brake Regulation
EBR Engine Brake Regulation
ECL Engine Coolant Level
ECT Engine Coolant Temperature
EDC Electronic Diesel Control
EDR Electronic Diesel Regulation
EDS Electronic Diesel System
EDW Anti-theft warning system
EFP Electronic Accelerator
E-Gas Electronic Accelerator
EGR Exhaust Gas Recirculation
EGS Electronic Transmission Control Gear system (Auto transmission)
EI Electronic Ignition (distributorless)
EIFI Electronic In-line Fuel Injection
EIS Electronic ignition switch ELCODE(DAS 3)
EL Exterior Lighting
EMSC Electric Mirror, Steering Column Adjustment, Heated Mirrors
EPB Electronic Parking Brake
EPC Electronic Power Control
EPH Parking aid
ERE Electronic In-line Fuel System
ESA Electric Seat Adjustment
ESA-R Electric Seat Adjustment Rear
ESC Electric Steering Column Adjustment
ESCM Engine System Control Module
ESP Electronic Stability Program
ETC Electronic Transmission Control
ETR Emergency Tensioning Retractor
ETS Electronic Traction System
EVAP P Evaporative Emission Control System
EVE Electronic Distributor-type Fuel Injection
EZL Distributor Ignition System
EZS Electronic Ignition Switch
FAN Fanfare Horns
FFS Frame Floor System
FGR Speed Control
FOM Folding Outside Mirrors
FP Fuel Pump
FTC Front transmission control
GAL Geschwindigkeitsabh ängige Lautstärke (Speed dependent Volume)
GIM Governor Impulse Method
GM Base Module (Master Ecu Controller)
GRM Gear recognition module
GUB Seat belt extender
GUS Seat belt tensioner
HAL Rear wheel steering
HAU Automatic Heater
HBF Rear Control Panel (Rear Control Field - arm rest buttons)
HCS Headlamp Cleaning System
HEAT Automatic Heater
HFM Hot Film Engine Management
HFS Hands Free System
HHT Hand Held Tester
HM Heated Mirrors
HORN Horn system
HRA Headlamp range adjustment
HS Heated Seats
HZS Additional trunk lid lock
IAT Intake Air Temperature
IC Instrument Cluster
IDC In Dash Controller
IFI Electronic In-line Fuel System(diesel)
IFZ Infrared Remote Central Locking
IL Interior Lighting
IR Infrared
IRCL L Infrared Remote Central Locking
IRM Inside Rearview Mirror
IRS Interior compartment protection
ISC Idle Speed Control
ISM Intelligent Servo Module
KAF Retractable rear head restraints
KAT Catalytic Converter
KBE A/C Operating Unit
KBE-H Rear A/C Operating Unit
KE Continuous Injection System (Cis)
KFB Convenience Feature
KG Keyless go
KI Instrument Cluster (Kombi)
KLA Air Conditioning
KS Knock Sensor
KSS Knock Sensor System
Lamp (Check Engine)
LCP Lower control panel
LCT Low Cost Teleaid
LH LH Sequential Fuel Management Bank 1 (1-6 or 1-8 Cylinders)
LH2 LH Sequential Fuel Management Bank 2 (7-12 Cylinders)
LH-S SFI LH Sequential Fuel Management Bank 1 (1-6 CYLINDERS)
LHS Left Hand Steering
LKV Air Fuel Ratio (Luft-Kraftstoff-Verhältnis)
LL Idle - Closed throttle
LLR Cruise Control
LOC Low Compression
LS Loudspeaker System
LS Power steering
MAF Mass Air Flow
MAP Manifold Absolute Pressure
MBC Magic Body Control
ME Motor Electronics
MIL Malfunction Indicator Lamp (check engine)
MOST Media Oriented System Transport bus
MKL-HL Multicontour Backrest - Rear Left
MKL-HR Multicontour Backrest - Rear Right
MRM Real name for the Steering Column Module
MRV Monitoring, Reporting and Verification (MRV) emissions data labelling (they add this with the F SAM update on early w221 in europe)
MSC Mirror, Steering Column Adjustment, Heated Mirrors
MT Manual Transmission
MVA Manifold Vacuum Assist
MWH Main Wiring Harness
NAG1 New Automatic Gearbox Generation One (5G tronic)
NAG2 New Automatic Gearbox Generation Two (7G tronic)
NSG New Shifting Manual Transmission
NS Network System (CAN)
NTG Natural gas-fuelled engine
O2S Oxygen (O2) Sensor
OBD On-board Diagnostics
OC Oxidation Catalytic Convertor
OCP Overhead control panel (roof module)
ORM Outside Rearview Mirror
OSB Orthopedic Seat Backrest
PDC Predrive Check
PL Power Lock
PML Speed-sensitive Power Steering
PMP Partial Intake Manifold Preheater
PNP Park/neutral Position
PS Power Steering
PSE Pneumatic System Equipment
PTS Parktronic System
PW Power Windows
PWM Pulse Width Modulation
RB Roll Bar Control
RCL Remote Central Locking
RD Radio
REST Residual Engine Heat Utilisation
RFH Reversing aid
RFH Backup Camera (Reversing Camera)
RFK Rear View Camera (Rückfahrkamera)
RFL Radio frequency locking
RHR Retractable Rear Head Restraints
RHS Rear Heated Seats
RPM Revolutions Per Minute (Engine Speed)
RS Roadster softtop
RST Roadster Soft Top
RTG Retractable Trunk Lid Grip
RTR Remote Trunk Release
RV Roadster Soft Top
RWD Rear Window Defroster
SAM Signal Acquisition Module (BCM - Body Control Module)
SAM-H Rear SAM (H = Hinten AKA rear)
SBC Sensotronic brake Control
SBE Seat Belt Extender
SCM Steering Column Module (MRM)
SCN Software Calibration Number
SEM Security module (up to model year 1999)
SDV Speed Dependent Volume
SFI Sequential Multi-Port Fuel Injection
SGR Parking Radar Control Unit (wide angle support for the DTR)
SHD Tilting/sliding roof
SHI Closing aid (Power closing)
SLO Starter Lock-out
SMS Service Microfiche System
SOR Seat Occupied recognition
SPS Speed-sensitive power steering
SR Sliding/Pop-up Roof
SRA Headlamp wash/wipe system
SRB Signal Relay Board (fuse box)
SRB-H Rear Signal Relay Board (fuse box in the rear)
SRS Supplemental Restraint System (Airbag)
STH Stationary Heater
SVMCM Special vehicle multifunction control module
TB Throttle Body
TC Transmission Control
TC Turbo Charger
TCM Transmission Control Module
TD Speed Signal (Time Division) (EZL)
TDC Top Dead Center
TIC Transistorized Ignition Control
TN Speed Signal (EZL/AKR)
TPC Tire Pressure Control (Tyre in English !)
TRAP Trap Oxidizer
TS Towing Senso
TV Television Tuner
TVV Tank Ventilation Valve
TWC Three Way Catalytic Convertor
TTU Tuner Amp (with Premium Surround)
TUA Tuner Amp (Standard)
UCP Upper control panel (front heater buttons)
UCI Universal Communication Interface (USB / other connector)
UHI Universal Handy Interface (phone module connector)
URB Roll Bar Control
VAF Volume Air Flow
VCS Linguatronic (Voice control system)
VCV Vapor Control Valve (VCV)
VHG Retractable trunk lid handle
VP Vacuum pump brake booster
VR Vario roof / Rollover bar (Electrohydraulic softtop)
VSS Vehicle Speed Signal
WOT Wide Open Throttle (Full Load)
WS Wiper System
XALWA-L Xenon headlight Left
XALWA-R Xenon headlight Right
ZAN Central Display (comand screen)
ZBE Real name for the Comand Knob
ZUV Additional vacuum supply
ZV Central locking system
BR "Baureihe" model series
C "Coupe or Cabriolet" body style
D "Tractor" vehicle is equipped with a diesel engine
E “Einspritzung“ is assigned to gasoline/petrol models (Einspritzung = Injection)
G “Geländewagen” off-road vehicle
K “Kompressor“ a supercharged or turbo charged induction system
L “Leicht” (lightweight) for sporting models
Lang "Langer Radstand" (long) Long-wheelbase, for sedan models
R “Rennen” (racing), used for racing cars.
S "Sonderklasse", Special class, for flagship luxury models
T “Touring” an estate or station wagon body style
4MATIC vehicle has all-wheel drive
BlueTEC “BlueTEC” diesel engine with selective catalytic reduction exhaust after treatment
BlueEFFICIENCY "EFFICIENCY” special fuel economy features
CGI Charged Gasoline Injection, indicates gasoline direct injection
CDI Common-rail Direct Injection, indicates a common-rail diesel engine.
Hybrid Petrol / gasoline or diesel-electric hybrid.
Turbo designates a turbocharged engine.
218 REAR-VIEW CAMERA
220 PARKTRONIC SYSTEM (PTS)
223 REAR BACK REST ADJUSTMENT AND HEAD RESTRAINTS, ELE
224 REAR SINGLE SEATS
229 PARK ASSIST
230 PARKING GUIDANCE
231 GARAGE DOOR OPENER
232 GARAGE DOOR OPENER
233 AUTONOMOUS INT. CRUISE CONT. PLUS (DISTRONIC PLUS)
234 BLIND SPOT ASSISTANT
236 DAY DRIVING LIGHT
237 ACTIVE BLIND SPOT ASSIST
238 ACTIVE LANE KEEPING ASSIST (FAP)
241 FRONT SEAT LH ELECTRIC ADJUSTABLE WITH MEMORY
249 INSIDE AND OUTSIDE MIRROR AUTOMATIC DIMMING
260 TYPE DESTINATION ON TRUNK LID - ELIMINATION
264 LICENSE PLATE AMERICA
275 MEMORY PACKAGE (DRIVER SEAT, STRG. COL., MIRROR)
276 MEMORY REAR SEAT
287 THROUGH LOADING FEATURE
289 LEATHER STEERING WHEEL WITH TRIM INSERT
294 KNEE AIRBAG
297 ELECTRIC ROLLER SUN BLINDS IN REAR DOOR LH AND RH
299 PRESAFE
301 ASHTRAY PACKAGE
310 DUAL CUP HOLDER
345 RAIN SENSOR
359 TELEAID LOW COST
386 MOBILE PRE.-INSTALLATION (MTUS)
388 PHONE MOBILE, MTUS-SYSTEM
389 MOBILE PRE.INSTALLATION (MTUS) USA/CANADA COMPL.
390 LINGUATRONIC
401 FRONT SEAT CLIMATE CONTROL
402 REAR SEAT CLIMATE CONTROL
406 MULTI-CONTOUR REAR SEAT
413 PANORAMIC SLIDING SUNROOF/GLASS SUNROOF
414 ELECTRIC TILT/SLIDE SUNROOF IN GLASS VERSION
416 INSTRUMENT WITH MILAGE READING
427 AMG Speed Shift MTC 7 AUTOMATIC TRANSMISSION 7-SPEED
432 MULTI-CONTOUR, DYNAMICS SEAT FRONT LEFT AND RIGHT
435 HEAD RESTRAINTS,REAR, PNEUMAT.FOLDING UP/DOWN
436 COMFORT HEADREST DRIVER AND FRONTPASSENGER
437 COMFORT HEADREST REAR
440 TEMPOMAT (CRUISE CONTROL)
443 HEATED STEERING WHEEL
461 INSTRUMENT WITH MILES IND. AND ENGLISH LEGEND
471 MECHANICAL LOCKING DIFFERENTAIL
474 DIESEL PARTICULATE FILTER
475 TIRE PRESSURE MONITOR (TPM) HIGH LINE/MID LINE
477 TIRE PRESSURE LOSS WARNER
487 ABC SUSPENSION (ACTIVE BODY CONTROL)
489 AIRMATIC DUAL CONTROL / AIR SUSPENSION SEMI
494 U.S. VERSION
500 OUTSIDE REAR VIEW MIRROR LH AND RH FOLDING
512 COMAND APS WITH DVD CHANGER
513 TRAFFIC SIGN RECOGNITION
517 HD RADIO
518 UNIVERSAL COMMUNICATIONS INTERFACE (UCI) / IPOD INTEGRATION KIT / MEDIA INTERFACE
527 COMAND DVD APS WITH DVD WITH NAVIGATION
530 COMAND DVD APS USA WITH NAVIGATION
536 "SIRIUS" SATELLITE RADIO COMPLETE SYSTEM
537 DIGITAL RADIO STANDARD DAB (DIGI. AUDIO BROADC.)
538 ATTENTION ASSIST (FATIGUE DETECTION)
540 ROLLER BLIND, ELECTRIC, FOR REAR WINDOW
551 ANTI-THEFT/ANTI-BREAK-IN WARNING SYSTEM
573 CHILD SEAT MOUNTING, ISOFIX IN REAR
580 AIR CONDITIONER
581 AUTOMATIC CLIMATE CONTROL
582 AUTOMATIC CLIMATE CONTROL IN THE REAR
584 ELECTRIC WINDOW REGULATOR
595 HEAT INSULATING+IR REFLECTG.SAFETY GLASS SIDE+REAR
596 HEAT INSULATING+NOISE INSULATING+IR REFLECTG.LAMINATED GLASS
600 HEADLAMPS - CLEANING EQUIPMENT
608 AUTOMATIC HIGH BEAM SWITCH (IHC)
610 NIGHT VIEW ASSIST
615 BI-XENON HEADLICHT W.ACTVIE CURVELIGHT RIGHT-DRIVE
616 BI-XENON HEADLICHT W.ACTVIE CURVELIGHT LEFT-DRIVE
618 BI-XENON HEADLAMPS FOR LEFT-HAND TRAFFIC
619 CORNERING ILLUMINATION
621 HEADLAMP WITH ILS, LEFT-HAND TRAFFIC
634 DELETION FIRST AID KIT
636 DELETION WARNING TRIANGLE
666 PRODUCT PROT.F.TRANSPORT VEH. W/O TIE-DOWN HOOKS
668 PRODUCT PROT.F.TRANSPORT VEH. W/ TIE-DOWN HOOKS
669 SPARE WHEEL / FOLDING WHEEL
682 FIRE EXTINGUISHER
690 EMERGENCY SPARE TIRE (MINI SPARE)
769 AMG 20" SPOKED WHEELS WITH MIXED TIRES
731 TRIM PIECES - WOOD BURRED WALNUT VENEER
736 TRIM PIECES - WOOD ASH BLACK
763 RADIO REMOTE CONTROL W/ PANIC SWITCH (315 MHZ)
776 WHEEL COVERING FOR AMG 17
771 20" AMG DOUBLE-SPOKE WHEELS WITH MIXED TIRES
772 AMG STYLING PACKAGE
780 19" AMG SPOKE WHEELS ALL ROUND
788 19" AMG MULTI SPOKE WHEELS W/ MIXED TIRES
802 ?
807 YEAR OF MODIFICATION
809 AEJ 08/1
810 PREMIUM SOUND SYSTEM
811 ADVANCED SOUND SYSTEM
814 DVD CHANGER
817 SIREN BRACKET FOR INCREASED THEFT PROTECTION
856 PHONE HANDSET IN REAR ARMREST
863 TV-TUNER DIGITAL TO ANALOG
864 REAR ENTERTAINMENT (2 SCREENS)
867 FRONT PASSENGER ENTERTAINMENT (Split View)
875 HEATED SCREEN WASH SYSTEM
876 INTERIOR LIGHT ASSEMBLY (ambient lighting)
881 REMOTE TRUNK LOCKING
882 INTERIOR SAFEGUARD
883 POWER CLOSING SYSTEM (soft closing doors)
885 HIGHTEN THEFT PROTECTION
887 SEPARATE TRUNK LID LOCKING
889 KEYLESS - GO
910 DYNAMO WITH HIGHER CAPACITY (FFO)
927 EURO 6 TECHNOLOGY EXHAUST GAS CLEANING
954 EQUIPMENT PACKAGE FOR AVANTGARDE VEHICLES
968 COC PAPER EURO 6 TECH. W/O REGISTRATION CERT.PART 2
983 COC PAPER EURO 4 TECHNOLOGY W/O REG. CERT. PART II
989 IDENTIFICATION LABEL UNDER WINDSHIELD
A21 SHIFT BY WIRE
A22 NEW CONVERTER GENERATION
A24 JOINT FLANGE, 4-ARM 120
A36 TORQUE CONVERTER HOUSING AGA
A41 SOFTWARE 2
A44 SOFTWARE 3
A45 O-SHIFT PLATE WITH VGS2
A50 ENGINE BRACKET VARIANT
FV SEDAN, LONG
G907 TRANSMISSION CODE VERSION 07
GA AUTOMATIC TRANSMISSION
HA REAR AXLE
H73 TRIM PIECES CARBON HIGH GLOSS
K10 SOFTWARE CONTROL FOR STATIC CURVE ILLUMINATION
K11 ADAPTIVE STOP LIGHT FLASHING
M642 V6 DIESEL ENGINE OM642
M273 V8-GASOLINE ENGINE
M273 M156 V8 GASOLINE ENGINE
M156 AMG M020 BLUETEC
M30 DISPLACEMENT 3.0 LITRE
M55 CAPACITY 5.5 LITRE
M63 6.3 LITRE DISPLACEMENT
R01 SUMMER TIRES
R24 17" LIGHT-ALLOY WHEEL 5-SPOKE DESIGN ALL-ROUND
P31 PERFORMANCE PACK
U01 REAR BELT STATUS INDICATION
U18 AUTOMATIC CHILD SEAT RECOGNITION (AKSE)
U26 FLOOR MATS
U37 FOG LAMP
U60 PEDESTRIAN PROTECTION - ACTIVE ENGINE HOOD
U72 DVD PLAYER WITH REGIONAL CODE 2, EUROPE, JAPAN
V23 SPEED- + LOAD INDEX 99W
VL LEFT FRONT AXEL HALF
VR RIGHT FRONT AXEL HALF
33P DRIVING SCHOOL BONUS PACKAGE 1
34P DRIVING SCHOOL BONUS PACKAGE 2
58U ROOF INTERIOR TRIM GRAY FABRIC
81P COMAND WITH NAVIGATION UPDATE
88V SPEED- + LOAD INDEX ZR20 XL+ZR20 XL
89V SPEED- + LOAD INDEX ZR19 XL+ZR19 XL
99N STEUERCODE WERK SINDELFINGEN/GRAZ ...TAX CODE SINDELFINGEN/GRAZ PLANT
Old Jan 7, 2024 | 12:36 PM
BOTUS's Avatar
S500
just pulled my list - has other parameters / changes
Anfahren im 1. Gang in C -------------Starting off in 1st gear in C INACTIVE
Freigabe PNC -GM1 -------------------Enable PNC -GM1
Momentenerhoehung -----------------Torque increase allowed, supervision. in MSG (engine control unit)
Pedalkennlinie KLD 1: A207,211,212,218,219,221,230 2x4 od. 4x4 ---Pedalkennlinie KLD 1: A207,211,212,218,219,221,230 2x4 or 4x4
Zuendwinkelkorrektur Warmlauf -------Ignition correction at cold start, without ZWK warm-up
I forgot to double check the pedal curve option listed for my actual car - they are slightly different (drops 209 completely) red is what the demo Xentry suggested - black is what's actually inside my car's brain
Pedalkennlinie (option 1) KLD 1: A207, A209, 211, 212 ohne M273Allrad, 219, 221 und 230 mit NAG1-Allrad oder NAG2
Pedal characteristic curve (option 1) KLD 1: A207, A209, 211, 212 without M273 all-wheel drive, 219, 221 and 230 with NAG1 all-wheel drive or NAG2
Pedal characteristic curve (option 1) KLD 1: A207, A211, 212, 218, 219, 221, 230 2x4 or 4x4
Pedalkennlinie (option 2) KLD 2: alle Fahrzeuge mit NGSG, BR251 mit KE55
Pedal characteristic curve (option 2) KLD 2: all vehicles with NSG, BR251 with KE55
Pedalkennlinie (option 3) KLD 3: BR164, BR251 ohne KE55
Pedal characteristic curve (option 3) KLD 3: BR164, BR251 without KE55
Pedal characteristic curve (option 3) KLD 3: BR164, BR251 without KE55, 639, X204
NOTE BR
(Baureihe) = model series
Pedalkennlinie (option 4) KLD 4: BR171, 203, 204, C207 und C209 mit NAG1-Allrad oder NAG2
Pedal characteristic curve (option 4) KLD 4: BR171, 203, 204, C207 and C209 with NAG1-all-wheel drive or NAG2
Pedal characteristic curve (option 4) KLD 4: 171, 204 oh. FX, C207, 463 NAG1-4x4 or NAG2
So curve 2 was supplied on vehicles using 5.5 litre M273 engine - and reintroduced in a clearance R class R 500 in the between years 2009 to 2012
The 2005 251 R-Class, got the then new 5.5-litre V8 motor with the R 500 and R 63 AMG models, but were withdrawn from the market in 2007. It came back with the facelift of 2010 reintroducing the R 500 but it was not offered in the North American market. They continued in long wheelbase form with the R 350 4MATIC and R 350 BlueTEC 4MATIC using V6 engines only in 2011 and 2012
ha - so the CL 216 never got a throttle pedal - ummm... I guess they just put the S class map on the 2 door car
Old Jan 7, 2024 | 01:51 PM
kevm14's Avatar
What's your theory about the difference given the applications?
Old Jan 7, 2024 | 02:44 PM
BOTUS's Avatar
S500
I don't know - its all a bit strange
I guess manuals having its own curve is sensible - you need consistency to judge bite point and throttle
A lazier pedal offsetting torque increase from mechanical advantage of a TC at low RPM makes sense - but now we have millions of gears and powerful engines (negating any logic ????)
How does the curve relate to the morphing insanity of adaptive lunacy ???? https://www.mercedesmedic.com/reset-...-instructions/
Why is there pedal curve 4 .... 2 door cars / shorter cars / lighter cars - or we have no idea and just played a bit when making them ???
Does fiddling confuse other safety or lengevity elements of how they made the car
Old Jan 10, 2024 | 12:31 PM
  #32
BOTUS's Avatar
S500
ha - so the CL 219 never got a throttle pedal - ummm, I guess they just put the S class map on the 2 door car
Old Feb 11, 2024 | 10:33 AM
  #33
kevm14's Avatar
Read my ECU coding out of DAS for fun.
- Vehicle speed regulation. Meaning, speed limiter disabled? Well, I have that OE Tune on it and I have seen almost 140 mph with a 130 mph limiter, so I guess this flag basically controls whether it even cares about the limit. That would explain my results.
- Speed increase air conditioning. I think this might raise engine RPM during A/C use which is interesting. It's off here and it looks like it's off in BOTUS's car, too.
- Load jerk damping. This is one of the settings that I had BenzNinja code to off, which significantly improved throttle response especially in certain scenarios.
- Torque limit stuff. Set to inactive. See previous comment.
- Torque increase. I think this is set to factory but I forgot what it might do.
- Accelerator pedal curve. This is set to factory and I think this means characteristic #1.
- Low fuel grade. Says yes. I don't know what this means. I will have to investigate. I could find NOTHING in the ECU regarding learned knock retard stuff but this suggests it thinks I am running insufficient octane fuel. I have heard knock on certain occasions with this OE Tune so maybe that is related.
Old Feb 11, 2024 | 11:33 AM
  #34
BOTUS's Avatar
S500
Accelerator pedal curve(s) Characteristic 1.5 ???
knock is so dangerous you don't learn or adapt for it you STOP it that instant - and measure and adjust live all the time
Old Feb 11, 2024 | 12:12 PM
  #35
BOTUS's Avatar
S500
decided the bit in quotes isn't going to work for you... (where I say Octane in this first paragraph below is to avoid finding the correct technical term for a fuel's normal burn speed)
A petrol vehicle's ability to spot and adjust for lower or higher quality fuel is not 'knock correction'. The vehicle has a method to ascertain Octane, but these days I guess could optimise or indeed have additional maps for ethanol rot fuels... It seems that capability can be enhanced - AKA set to think rubbish is the new normal - using the element you query in your post about 'low grade fuel'. I'm guessing the Octane sensing uses the same sensors, but its not a knock adjustment - rather giving the vehicle a kick all the time to do something different...
'knock' is a sudden violent explosion of the fuel usually when put under a high stress engine load condition - and is often in play for only a few milliseconds (on a std vehicle using products its meant to have in it).
Whereas crap fuel with lower than normal Octane, I guess is noticed straightway at engine start up (by those very same knock sensors) - rather than try to adjust there and then continuously for knock - which it will struggle to achieve due to 'the risks' of operating with substandard fuel. Instead it says to the engine ECU - the moron's put crap in the tank... don't temporarily tweak the ignition curve - swap ignition maps to a moped version, (and will do this all the way till it has no lower ignition maps to use), its one reason different markets get different base maps...
That thought process - explains how you could do it with equipment fitted on modern engine management systems, and for a bike I owned that was designed to run 98 or higher - it 'instantly' changed when I put 99 Octane in it for the first ever time (from 97 that was previously highest available at the time). It literally upon start up, sounded and idled like like a very different vehicle. And within 10 yards of pulling away I could feel it had a lot more power everywhere... the gains felt like a 20% tune up in less than 1/4 of a millisecond after start from filling the tank...
If you delve inside the code of an engine map (say with WIN OLS) where you can load 'the map', and look at weird 3D graphics of the insanity - you'll see there is literally vast quantities of strange stuff going on in there - way more than you'd find overdosing on magic mushrooms for a week...
Old Feb 11, 2024 | 12:22 PM
  #36
kevm14's Avatar
It's what I would call light knock, probably only detectible to folks who know what it sounds like. I wanted to see if there was a knock retard history adaptation just to get an idea but I didn't find any. I use US 93 octane exclusively. The light knock I sometimes hear is at lower RPM under heavy load. I can't stress enough - it is very subtle, not loud clanking that sounds like the engine will fall out. If the radio is on, I wouldn't hear it. There is a chance I am not hearing knock, but my trained ear says that's what it is.
Full disclosure: I have tuned engines before, so I know all about how timing, knock retard and general engine control parameters work.
On 90s GMs, there was a "low octane" timing map that would be invoked in circumstances where repeated knock (and thus knock retard) was needed. Eventually it would surmise that you must be using a lower octane fuel than you should be, so it goes ahead and uses a more relaxed spark table, rather than continually just fighting each occurrence. My understanding is at a new tankful, it would give the proper timing table a chance again. Some knock and spark retard here and there is not grounds for using this low octane table, btw.
So, my thought was perhaps that's what "low fuel grade" means. Could be a learned thing. OR, it is a hard coded thing but I still don't know what it means. Maybe it means NOT using E85. But that is a very strange way to word that, if so.
I also noticed "RON correction" which might be simply enabling the ability to detect general octane levels (based on knock sensor performance and trends). I am just guessing though.
Old Feb 11, 2024 | 01:07 PM
  #37
BOTUS's Avatar
S500
we just wrote the same thing.... although I think the speed vehicle's do all this has increased a lot versus how you pitch it
I don't like the sound of the 'knock' you are describing - does it say yours is a 4x4 ? if so that might be part of it... modern Traction control (and indeed my experience of how well my rear drive one manages this) might allow a 4x4 to try and place more grunt on the road.. so where my car its saying give up the grips gone and the engine gets an easy life - a 4x4 might be saying come on engine give it some more, all the way till it complains ?
another thought as the 4x4 might be for up a mountain and or strange parts of the world where rubbish fuel is 'normal' is it set to be more conservative on its base map ?
Mine is not set to use low grade fuel
Old Feb 11, 2024 | 01:14 PM
  #38
kevm14's Avatar
I guess the colloquial term that would normally be used to describe what I think I am hearing is pinging. At least on my side of the pond. It's not all the same in terms of severity.
Old Feb 13, 2024 | 08:16 AM
  #39
Oderfla's Avatar
mercedes s 500 w221 año 2005
Hello Kevm14 y Botus
Hello good Morning. Botus and Kevm14. I wanted to ask you a question. This encoding is only possible with vediamo or dts monaco??? I ask this because today with my xentry/das with which I have coded many things in my car without any problem. Today when trying to deactivate these two options Lastschlagdaempfung and Momentenbegrenzung I got an error. It won't let me do the coding very strange. I did it with the car without starting and it gave me an error. then with the car started and the same thing. I tried doing other encodings to see if it was a xentry/das error and I can encode without problem. but I can't disable these two options. what am I doing wrong. ???? It is only possible with monaco and and vediamo. ????? Or am I missing something in my xentry/das???? . It's the first time I can't code something in my car. Can you please help me. As always, I appreciate your help. Receive cordial greetings from Spain. thank you
Old Feb 13, 2024 | 01:43 PM
  #40
BOTUS's Avatar
S500
it appears certain iterations of Merc kit is either simpler to use (old pre 2012) or some stuff needs the developer mode enabled which lets you get as stuff you won't understand and lets you really destroy the car fully
I found mine in developer mode where its all in the wrong language - but kevm14 and Benzninja look to have found it in the normal children's mode - where they handily write it in English (or local language - where supported) - maybe I didn't try hard enough
I do see certain pop ups where it isn't behaving within children's mode now and then (its quite offensive when it does that)
I don't know enough if the ME9.7 needs high level access (maybe....) my kit has the DOIP multiplexer, what's yours ?
TRY another look about - AND don't forget playing in driveline related stuff really needs battery support - low volts and introducing bugs here is not so clever
Don't ever write to the engine ECU with it running...
Old Feb 13, 2024 | 02:17 PM
  #41
Oderfla's Avatar
Botus
Hola Botus, gracias por tu respuesta. comp siempre ayudándome en todo con su gran conocimiento. bueno te lo diré. Tengo xentry/Das passthru versión 07/2016 con interfaces openPort 2.0 con modo desarrollador y programación offline y la verdad me funciona de maravilla y solo lo uso en mi coche Mb s500 w221 del 2006. Lo tengo codificado y activado bastante algunas cositas en diferentes módulos en el cuadro de instrumentos en el comando en el sam trasero etc. y nunca sin un solo error. y ahora quiero intentar desactivar estas opciones del acelerador y me da este error. He buscado información en varios foros y se dice que en DAS primero hay que desbloquear la ECU para permitir esta codificación. He buscado en modo desarrollo pero no encuentro esta opción. desbloqueo. También sé que lo mejor es tener un BENZ NINJA xentry DAS. pero como comenté, hasta hoy he podido activar y codificar todo lo que me propuse. También se dice que con Vediamo y Mónaco este trabajo es muy fácil. Pero yo no tengo esos programas y hay que saber trabajarlos muy bien porque puedes arruinar el auto. Es una pena porque me hacía mucha ilusión ver cómo se comporta mi coche con estos cambios. gracias botus.
Old Feb 13, 2024 | 03:10 PM
  #42
JettaRed's Avatar
Veteran: Army
@Oderfla Does vediamo or dts monaco launch at all? I have the BenzNinja suite of software and on occasion have had Peter to redo the key that unlocks the programs that stop loading for some reason. I know the software is very temperamental to any environmental changes, such as a Windows update.
Old Feb 15, 2024 | 11:26 AM
  #43
BOTUS's Avatar
S500
time for some lunacy BMW put in bike maps ? for the egle eye's check the vertical scrollbars... it goes on like this for hours and hours - is it any wonder most remaps are quick nips and tucks on fuel and ignition curves - I don't think anyone knows what's really going on
Old Feb 15, 2024 | 02:00 PM
  #44
Oderfla's Avatar
Family
In the end I think I will be left with the desire to codify these two options that allow you this improvement in the accelerator in our cars. Today I tried the coding again with my XENTRY/DAD and with my voltage stabilizer. It won't let me save the coding. So I understand that you have to have Vediamo or Monaco and a high level to do this operation. And since I do not have these programs and I have never used them, in the end I cannot test this improvement. Look, I have coded many things in my car with xentry/das with developer mode and I thought that I would never get an error when coding any parameter. Now I see that there will indeed be many things that will not be possible with xentry/das. only with vediamo and monaco and a high level. Anyway, once again thank you as always for sharing your experiences and the improvements you make to our cars. a cordial greeting.
Old Feb 15, 2024 | 03:40 PM
  #45
kevm14's Avatar
FWIW I haven't heard the pinging in a while now. Is there a knock-related data PID somewhere that I can't find?
Old Sep 13, 2025 | 12:52 PM
  #46
FLASHBACK's Avatar
2013 E250CDI BlueEfficiency 4Matic
I have a question, is:
Lastschlagdaempfung
Available in mine W212 250CDI Produced 2013 06 212.098 ?
If so i would like to try to disable it with Vediamo 4.2.2 or Xentry
Old Sep 14, 2025 | 05:49 AM
  #47
kevm14's Avatar
You can check in Xentry. But I don't think you can change it in Xentry.
Old Jan 20, 2026 | 10:23 AM
  #48
BOTUS's Avatar
S500
not sure which bits all the throttle pedal fun referred to in this post is really tweaking - but mine was chipped by specialists just about the time kevm14 posted this thread - on my car the 2k rpm mid range throttle response was extraordinarily different - feeling like a different engine, with so much more grunt reaching the wheels it didn't make any sense - as I know its impossible to achieve this with a NA engine (non turbo) and a basic remap....
trouble was this dramatic performance change came with a nasty jolt / sensation I'd never noticed on the car before - I had only driven it for 3 days post chipping and I was still getting used to the extra go - when the other lot put in the blue trans fluid meant for the 7G+ box of 2010 - that gets an extra clutch plate in its modified TC lock up clutch... Unfortunately that wrong fluid sent the box in a tail spin with delayed shifts that muddied the waters
both changes were tweaked within 100 miles of this performance "bang" appearing - but then the massive performance increase waned (till I wonder if I lost it all) - the chip guys had it back and they lessened this new characteristic jolt / bang - and then they volunteered to swap the trans fluid when Fuchs tech support told them to get it out - and it was swapped back to the correct spec (giving it a free trans flush, that likely helped clean it up inside)
I came to the conclusion the extra grunt I had felt was really them smashing in the TC clutch far harder at lower revs, with a change in line pressure or such - but the jolt was nasty and the associated bang can't be a good idea... Obviously the chip tune keyboard power warriors have no idea Merc changed the TC clutches between the earlier likes to fail design - and the later ones with its extra clutch plate - and thus need to temper the tweaking to suit each box
Today I read more about TC lock up - obviously they no longer only cut in just on a light cruise in higher gears- that's long gone - I've known that for years, as you always notice the 7G doing the TC lock up incessantly in most gears - its a major reason why they wear out - but this specialist site (see below) are even claiming they deliberately slip the TC clutch in and out for emission fiddling / refinement purposes - leading to extreme wear in the gearbox (by adding swarf everywhere as the TC clutch fails) !!!!!
and they also mention two basic designs of TC lock up clutch -
some designs of TC lock up clutches are always on - and its switching that lifts it back into the normal slippage / torque increase mode ready for take off (potentially giving the always on - rough shifting / stalling failure mode Merc's suffer from)
whereas other designs it off and cuts in as required
https://www.transmissiondigest.com/h...ontrol-part-1/
https://www.transmissiondigest.com/t...ontrol-part-2/
