misfire
Well, I suppose if there is no injection of fuel, there is no pollution. Does the detection monitor the electricity or the sound?
Or perhaps not enough fuel ... which can mean too much air ... which suggests vacuum leak. It requires a rich mixture to get a cold motor running.
Perhaps the ecu doesn't get the message the engine is cold.
Also told me that if I had floored the gas pedal when starting it would have worked.
So, a simple test for you would be at the cold start floor the gas pedal and see if it gets going smoother. You naturally let pedal up right after it fires up.
If this test shows better engine start perhaps you have the “too much fuel” issue like I did…?
she also managed the same on a VW golf Mk2 - but this had fly by wire and if you ask for full throttle the computer says no - so it has zero effect - I took the plugs out and span it up with a screw drive holding on full chat and buckets of flue flew out the plug hole - it was Ok ever after
Bosch injection crap !
With direct fuel injectors one of then could well be dripping fuel into a cylinder overnight. If you replace one replace all eight. Being direct injection it won’t get ‘flooded’ as in the bad old days of carburetors so it would feel as a thud-thud-thud when first started with one cylinder not running until it clears up. Pull all spark plugs and look for one that stands out. That is the dead hole. Give it fresh spark plugs. Coils are also old enough to be suspect.
