Light tap on a gas pedal creates hight RPMs and slow return to idle gear lever in N p
Old Jan 9, 2025 | 05:00 AM
BOTUS's Avatar
S500
if it leaked that bad you lose oil - pistons going up and down tend to pump air out not suck it in - investigate the rest of the engine breather - many like to fit a new separator at the back of the engine as the miles increase
Old Jan 9, 2025 | 05:14 AM
ANEV's Avatar
S550
The separator is new, i have changed that part a few months ago, only the outside part because of the oil leaking, the other round part looks like new
Old Jan 9, 2025 | 05:18 AM
ANEV's Avatar
S550
Btw the car is loosing about 1l of oil for 4k km
Old Jan 9, 2025 | 08:34 AM
BOTUS's Avatar
S500
on the floor or burning out the exhaust - big difference
if its that out the exhaust - that's not too much if high miles - electroplated bores are a sick joke - and Merc make some of the most useless fragile coatings used by any brand
Old Jan 9, 2025 | 09:08 AM
ANEV's Avatar
S550
"on the floor or burning out the exhaust"- very good question! I cant detect any smell of burning oil from the exhaust, in other hand the floor of the car is not the cleanest, i already changed the oil cooler gasket and oil filter gasket(2 times) but it looks like i need to repair it again(its leaking again-Elring gasket are not the best i guess). It looks like the crankshat seal is leaking too, the area around is oily, maybe its because of leaking oil cooler and filter gasket... i alredy ordered crankshaft front seal, will change it and update... 201000km on odo, but 15 year old 😀
Old Jan 9, 2025 | 12:31 PM
BOTUS's Avatar
S500
that little oil used you likely won't see or smell it being burnt - but its is more than ideal, and again points toward worn electroplated bores that will make the car breath more heavily and it pushes stuff past gaskets and seal...
do a compression test - I believe you can get Xentry to do a pretend one - but of course that’s nothing like a real one
Old Jan 9, 2025 | 12:52 PM
  #32
ANEV's Avatar
S550
Its already done, real one. The shop says its perfect-12,5bar all 8 cylinders. I tryed the Xentry one but...i dont have additional source of electricity and seems to me that its not 100% real if done only with cars battery. I have done it one time, here it is the graph
Old Jan 9, 2025 | 12:58 PM
  #33
BOTUS's Avatar
S500
is the Xentry fake one not done with the engine running ?
that has a some discrepancy
if you were leaking 1tr externally you would see it clearly
what mileage ?
Old Jan 9, 2025 | 12:59 PM
  #34
BOTUS's Avatar
S500
FYI if I had the choice to pull one of these apart or say the compression was OK... what do you think my answer would be
Old Jan 9, 2025 | 01:06 PM
  #35
ANEV's Avatar
S550
I was not there...he take the money...maybe its not bad idea to make the test with my hands...tired of making all kind of stuff...
Old Jan 9, 2025 | 01:12 PM
  #36
ANEV's Avatar
S550
what mileage ?
The Xentry one is done with ignition on, brake and gas pedals fully depressed, and running the ignition(trying to start the car) for about 6-10 seconds. Odometer is at 201000km
