Welp Houston we got an issue
that’s a strange one - I bet it needs one of these
Interior Fuses Right side of the dash F1/6
F91 5 AMP Front SAM unit
as for the canbus bit - I wouldn't solder... crimp is the way - canbus only run 1 to 5 volts and almost no amps
Fuse Number Ampere Rating Designation
F70 40 Door Control Unit - Right Front N69/2
F71 15 Keyless Go Control Unit N69/5
F72 7.5 Pyrotechnical Separator K88
F73 5 Emergency Call System Control Unit
F74 30 TLC Control Unit
F75 10 Battery Management
F76 15 Vacuum pump relay
F77 50 Sound Amplifier A2/13
F78 25 AdBlue Relay/ Additional Fan/ Charge Air Cooler Circulation Pump
F79 7.5 Alarm H3/1
F80 40 Door Control Unit - Left Front N69/1
F81 40 Door Control Unit - Left Rear S Class N69/3
F81 30 Rear Control Unit - Rear CL model N22/6
F82 40 Door Control Unit - Right Rear S Class N69/4
F82 30 Rear Control Unit - Rear CL model N22/6
F83 30 Intelligent Servo Unit. Direct Select
F84 20 Sound Proceeding Unit A2/69
F85 10 AMG Illumination for Door Sills
F86 – Not used
F87 – Not used
F88 – Not used
F89 – Not used
F90 20 Heater unit
F91 5 Front SAM unit
Fuses Driver side, Left side of dash F1/7
F92 40 Left front seat N32/1
F93 7.5 Weight sensing system N2/13
F94 5 Camera
F95 – Spare
F96 5 TPM RDK Unit N88
F97 7.5 DVD Player
F98 – Spare
F99 7.5 COMAND
F100 5 Media Interface N125/1
F101 10 Rear Displays Left A40/5 RightA40/6
F102 40 Right front seat N32/2
F103 7.5 ESP Electronic Stability Program N47-5
F104 40 Audio Radio Tuner
F105 – Not used
F106 5 Navigation / TV Tuner/ Toll Collection
F107 5 HD Tuner N87/8, Audio Broadcasting N87/3, SDAR Sirus Unit
F108 5 Rear A/C N22/4
F109 15 Rear Air conditioner blower motor N29/2
F110 7.5 Rear Back rest control Unit N32/20 N32/21
F111 5 RCP Control Unit N72/2 - HBF Rear Control Field - (arm rest buttons)
F112 5 Front SAM Fuse box,
F113 5 DC Converter
F114 – Not used
Front SAM Control unit adaptations
later software LIST of codings for Front SAM
Parameterization MRV functional requirement
Parameterization of light
Parameterization of fan control unit box
Parameterization of recuperation: channel setting
Parameterization of the washing water level
Parameterization wipers
Parameterization of the wiper compartment heating
SRA Headlamp wash
Installation condition of the transmission oil cooler/water cooler
Installation condition LRK Steering wheel heater
Installation condition of the washer nozzle heater
Installation condition of the water valve
Monitoring, Reporting and Verification (MRV) Labelling re collection and analysis of emissions data
Parameterization of lights
Coding
Fog lights installed
Daytime running lights not installed
Daytime running light dimming not active
Daytime running lights dimming factor 90%
Cornering light substitution not active
Cornering light substitution fog lights not active
Retrigger time for headlight activation 1min
Replacement light function active
Parameterization of the fan control unit box
Coding
AC Ventilator control box installed
Coding
Parking light right voltage target voltage 13.0 V
Parking light right setting Recuperation active with standard target voltage
Parking light left voltage target voltage 13.2 V
Parking light left setting Recuperation active with standard target voltage
Fog light right voltage target voltage 13.5 V
Fog light right Recuperation setting active with standard target voltage
Fog light left voltage target voltage 13.5 V
Fog light left setting Recuperation active with standard target voltage
Daytime running light right voltage target voltage 13.8 V
Daytime running light right Recuperation setting active with standard target voltage
Daytime running light left voltage target voltage 13.8 V
Daytime running light left setting for recuperation active with standard target voltage
Sidemarker right voltage target voltage 13.8 V
Side marker right Recuperation setting active with standard target voltage
Sidemarker left voltage target voltage 13.8 V
Side marker left setting for recuperation active with standard target voltage
Direction indicator right voltage target voltage 13.8 V
Direction indicator right Recuperation setting active with standard target voltage
Direction indicator left voltage target voltage 13.8 V
Direction indicator left Recuperation setting active with standard target voltage
High beam right voltage target voltage 14.0 V High beam right
High beam left voltage target voltage 13.8 V
High beam left setting for recuperation active with standard target voltage
Terminal 58D voltage target voltage 13.5 V
Terminal 58D Recuperation setting active with standard target voltage
Low beam left voltage target voltage 13.5 V
Low beam left setting for recuperation deactivated
Low beam right voltage target voltage 13.8 V
Dipped beam right setting for recuperation deactivated
Storage compartment lighting center console voltage target voltage 13.5 V
Center console storage compartment lighting
Parametrierung Screen wash level
Coding
WW_ok_by_drive 3276750ms
WW_nok_by_drive 10000ms
WW_ok_by_stop 2000ms
WW_threshold 842
Parameterization Wipers
Coding
Wiper Start Suppression Active - active
Wiper Speed Reduction Active - active
Coding
Wiper parked postion heater - installed
SRA headlamp wash
Coding
SRA_EnSRAauto - active
SRA_EnKl15 is a functional requirement
SRA_EnAbbledlichtAnf is a functional requirement
SRA_EnStandlichtAnf is a functional requirement
SRA_Time 1100ms
Coding
Transmission oil cooler installed - not fitted
Water cooler installed - not fitted
Installation condition LRK (Steering Wheel heater)
Coding
Steering wheel climate control installed - installed
LRK duty cycle - variable control time
LRK duty cycle - fixed control time (24min)
Coding
Heated washer nozzle - installed
Coding
Water valve - installed
isn't that CGW way too late A2219006702 ? - Mine was a 2215408945 there is a later part that came with SW ending 1427 - but 1427 isn't compatible - it runs SW ending 1327 is the last that works (original was SW 2214481027)
Super Relay Buddy
yep, I found some other fuse charts and a number of fuses are only for the S400 Hybrid cars,
but searching again and it was listed in early cars for some odd bit - oh and magically its a 5 Amp (oops)
the other interesting thing is never call it the fuse boxes on the dashboard, Drivers / Passengers side... its Left side and Right side of the car regardless of where the steering wheel goes - yet the Front Sam does change sides with the wheel, just to aid no consistency whatsoever ???
If car was left at a shop for months and they were depleted,
Then get car home and fully charge the starter and trunk batteries
Test again. If it fails, purchase new batteries front/back, take them home, and fully charge them.
Test again. If it fails, it most likely is not the batteries.
