First ever check engine light!
A misfire that came out of the blue on cylinder #1 (P0351) the car began to run awful. I was down the road from my house so I turned around and went home. Scanned it, ran to Autozone and put a new coil in the #1 spot. Started it up cleared the code and went on my way. The car ran fine all day.
later in the day it through the check engine light again, but it was running fine. Scaned the car and I have a P0356.(ignition coil primary circuit of cylinder 4 is too low) cleared the code and it came back. The car is running fine. I checked the wires, and vaccum hoses they seem snug.
The coil packs and spark lugs were replaced at 64,000 miles by the MB dealership I bought the car from which was almost 9 1/2 years ago. My question is this, do coil packs tend to go in pairs or is this an odd occurrence? The car is running fine. Should I be looking at something else before I replace another coil pack? Tomorrow I'll do the swap and see if the code follows the coil pack. If it does, I'll have my answer if it doesn't what should I do next?
I still have 3 original coils sticks at 19 years and 74k miles still working as well as a good brand new one
Then I have 3 that died at 50k miles 9 years in and were replaced with secondhand ones of indeterminate age still going strong
and a further two that died at 65k miles and 15 years, again replaced with secondhand Merc OEM junk from ebay, again of indeterminate age
I would suggest mine will out last many of the ones where people replaced all eight with new (designed to randomly fail) junk the manu loves to peddle
they are just a bunch of sharks trying it on - just like the the rest of the world - mainly because the Germans have taught them all this very effective business model over the last 35 years
I decided Just for peace of mind I will replace the set. Ill keep a few of the old packs that I know are good in the trunk I case of a on the road issue. I never had a coil pack fail randomly without warning before. When I had a bad coil pack on my wife's GL550 it would occasionally stall, but never throw a check engine light. A pending lean code was present. It was a PIA to diagnose. The scary thing was that it would stall on the highway.
as for them dying - try a BMW - bikes lead the field used to manage 30k miles on the R1200 boxer twins - but things evolve - now many K1600 6 pot bikes will have them all start dying from 20k miles at any thing over 4 years - the week I sold my 2019 K1600 at just 10 k miles it missed like one was giving up on start up
as far as quality goes her ford vs my merc vs a BM bike - number of sparks before death - nothing suspicious going on here with German build quality !!!!!!!!!
good luck with the turnaround.!!!
you should pick up if some are properly duff...
I replaced the coils. I did the plugs too. The plugs looked fine. Everything is done, and the car is running well. It feels a bit more peppy. The Autozone coil I had installed lasted exactly 5 days before it threw a code. It was $83. I'm going to try and return it. Not cool, Autozone. It sucked changing out everything out in my driveway in 38* weather. The space heater and heated scarf I was wearing helped. What was worse was that coil 4 fell apart in my hand as I was disconnecting it. The head broke off in the harness. I had a mild panic attack as I wasn't sure how to remove it. At first, it looked like the pins were damaged; fortunately, they weren't.
Some years ago, I learned that the hardway. Replaced eight coils...then, replaced them all again one by one in about two months. Being as I have 36 spark plugs (in cars) in the garage. I keep coils handy. Fortunately, all the cars but the 300 take the same coil.
The 300 is a recent purchase. I was wondering if the coils were the same, and said to myself they probably aren't because it's a 4-cyl. I am really enjoying the SLC. My wife likes it too. That forum is beyond dead. It has tumble weeds blowing around.
