Indexing spark plugs
Here is another document that discusses the two approaches.
Just don't shield the spark from the injector. What is the discussion?
A far, far better question, is why, after all these years of intense, hair-pulling frustration do I still insist on replying to threads on this same, road-dead dog subject?
now that makes for interesting (and confusing) reading
the way I read ONLY the V6 gets the different engine for USA vs the Europe one - check page 8 and 9 no ref to the 278
My copper seal pre- crush is to make plugs turn just the needed angle. Two of them turned all 90 degrees, two only about 45 degrees where I left them. Motor runs good with the Bosch plugs from FCP and new coils from AutoZone.
on the passenger side of the engine I used a separate strong thick washers on an all thread. This was a M12x1.75 all thread that I got from the Kmac kit. Tightened to 23 Nm and after that turned 99 degrees. Washer thickness went from 1.5mm to 1.3mm as of this turned the plug to about 30degrees from TDC.
I will replace the four plugs I first did first using the method I explained above.
Assuming you plug is seated (with or without a torque wrench)?
Honestly, whether it’s a real issue or not, I find no harm in complying with the warning to index. 23Nm gets me within that 90° window. Of course, my 6 cylinders are probably easier to work on. I do mark the extension and socket to see how close I am to 0° when hitting 23Nm.
I try to get my new plugs close to same. I don’t see there is any harm doing that either.
most likely a learnt trick from the i people, marketing drivel to scare you in to using over priced servicing by franchised crooks - who actually employ sacked burger flippers
the nasty limits of early DI just damaged the engine - hence everything went backwards and now "modern engines" get port injection for normal work and hit DI in the emission lab during fake driving conditions - plus now they use special oils to try and keep the thing alive as start stop and chocolate camchains do their best to help you need a new vehicle
I think the difference between plugs with the MB logo and regular Bosch from parts stores is where the plug thread starts. I tried to look at this but it is very difficult to see from the plugs.
But it really can only be this as I measured the copper washers the same 1.5mm thickness between MB logo plugs and the ones I bought from parts store.
