W221 Electrical Gremlin. Help!
Old Dec 24, 2025 | 06:12 PM
221gremlin's Avatar
2010 Mercedes S550
Hello Everyone!
I’m having an interesting electrical issue, my 2010 S550 with only 77k miles has no communication with any module through OBD, no start no crank and flickering screen with errors (see video), I’ve put a brand new battery no luck, I’ve bought another gateway to plug in and still same flickering symptoms.
update: we have established connection after unplugging the headlights and connecting the original gateway, we could go into every module except eis so we sent our eis away to a tech and they found that the chip is shorted inside the eis so they replaced it, we now plugged everything in and got a new problem, when we go to crank both screens flicker like crazy as if there is a short somewhere and obviously again no crank!
what could this be?
YouTube link: https://youtube.com/shorts/oFyDjytk630?si=lwxzRTqpSDT-4B-x
Old Dec 24, 2025 | 06:22 PM
smiles201's Avatar
2023 E 450 Sedan. 2018 GLC 300. 2013 E 350 Coupe (retired)
Bad ground?
Old Dec 24, 2025 | 07:32 PM
221gremlin's Avatar
2010 Mercedes S550
Originally Posted by smiles201
Bad ground?
looks like something with wiring, I will check it all out, it’s never been flooded.
Old Dec 25, 2025 | 05:32 AM
BOTUS's Avatar
S500
Originally Posted by 221gremlin
Hello Everyone!
what could this be?
YouTube link: https://youtube.com/shorts/oFyDjytk6...xzRTqpSDT-4B-x
gateways are not plug and play
confused gateways give no comms to the ODB2 socket - and a battery reset (disconnect for 20 min) often sorts it out
however the other fun you are having isn't just a battery reset - replacing the other baby motorcycle battery behind the ignition switch likely not a bad idea
look for blown pre fuses and as other's mention poor earths
Old Dec 27, 2025 | 12:10 PM
Arrie's Avatar
Hello Everyone!
what could this be?
Like BOTUS already said the CGW is nt plug-and-play, it needs to be coded.
Put the original CGW back in as it may change things if it is the issue with the bad connections between the harness pins and the board, like I had the issue with. Re-connecting the old CGW may move the pins and allow better connection again.
This may be the cluster issue too.
Old Jan 7, 2026 | 10:58 PM
221gremlin's Avatar
2010 Mercedes S550
Update!
Old Jan 7, 2026 | 11:18 PM
Arrie's Avatar
I would look at the starter. When they go bad they can rob the amps/voltage from other modules, so the car won't start even when it cranks fine. Now you say it does it not even crank so I would really look at the starter.
Old Jan 8, 2026 | 12:40 AM
221gremlin's Avatar
2010 Mercedes S550
that’s what I’m also thinking maybe the old owner drove through a big puddle or large amount of water and maybe it corroded the starter and shorting it, I will investigate tomorrow after work!
Old Jan 8, 2026 | 01:09 PM
JohnLane's Avatar
222 S-65
Or maybe... Just maybe it; at the tender age of 15 is old enough that a starter, Central Gateway, EIS or any of the other myriad issues that happen that can be a real treat to sort out have failed.
May the Force be with you Friend.
Old Jan 9, 2026 | 12:39 AM
BOTUS's Avatar
S500
if you are running a late spec CGW that is not programmed with the correct software iteration and coded to suit options on the car - it can not operate correctly - indeed I presume damage could be achieved
Old Jan 9, 2026 | 09:56 AM
AL5461's Avatar
W221 S500
Never flooded? Are you sure about that? Lift the front carpets and check for ANY signs of moisture in the CANBUS junctions and treat it accordingly.
For testing purposes, the CGW can be swapped for another. True some features may not function, unless it's correctly optioned. From experience this is easily done using Xentry... However, you cannot change Vehicle Vin or Mileage after the initial programming of the CGW and you will get a code for the VIN mismatch.
Old Jan 9, 2026 | 10:16 PM
221gremlin's Avatar
2010 Mercedes S550
Latest update. Car started
Hello Everyone!
what could this be?
ok guys the car has finally started, i got back the eis from the tech and he found a bad chip that overheats and shuts down the eis. Now the car sometimes starts but it also starts glitching when it wants to and loses connection with all modules and sometimes again can’t be started. New video link attached.
Old May 20, 2026 | 04:31 PM
221gremlin's Avatar
2010 Mercedes S550
Smile SOLVED!
The problem with 2010 S550 is finally solved.
Issue was in the EIS shorting inside and causing electrical problems, replaced it and coded now its all working again
