steering wheel button replacement
Old May 17, 2026 | 09:01 AM
RichDMB's Avatar
2008 S550
So for $30 on Amazon you can get the 4 button set for the steering wheel. The listing says you just need to pop out the old ones and press in the new ones, sounds simple. Has anyone tried these?
Amazon.com: Partscollect Black Interior Steering Wheel Button Replacement Kit Compatible for Mercedes-Benz W221 S- CLASS S550 S450 S600 S65 S350 S400 S500 CL550 CL630 2007-2010 : Automotive Amazon.com: Partscollect Black Interior Steering Wheel Button Replacement Kit Compatible for Mercedes-Benz W221 S- CLASS S550 S450 S600 S65 S350 S400 S500 CL550 CL630 2007-2010 : Automotive
Old May 17, 2026 | 11:21 AM
AL5461's Avatar
W221 S500
Pop them out is a bit of an understatement. From memory they're screwed in.
Unless they're physically damaged, they do clean up but it takes effort. Don't use solvents on them.
My go to is foaming upholstery cleaner on a microfibre cloth.
Old May 17, 2026 | 01:43 PM
Senecat's Avatar
1983 Nissan Shltbox
Bought a set for my 212. Haven't installed them yet. Good vids on YT. Easy job.
Old May 17, 2026 | 02:14 PM
AL5461's Avatar
W221 S500
Can confirm they are screwed in. Airbag off job.
Old May 19, 2026 | 12:10 AM
Arne Ruhr's Avatar
W221 S550
I installed them a few years ago. Still look good. But the airbag has to come out. Two hints:
1. Be careful with the tiny screws. They do not allow unlimited cycles of loosening and tightening.
2. The chinese buttons rattled, which was annoying. I had to pull everything apart again and used some flexible sealing compound along the circumference of the buttons inside of their little casings. That quieted them down.
Old May 20, 2026 | 09:17 PM
RichDMB's Avatar
2008 S550
Seriously, you have to disconnect the airbag?!!
Old May 21, 2026 | 11:28 AM
EasyPhil's Avatar
2007 S550 4Matic 2013 S550 Base
Of course you do, that buttons are on the air bag assembly.
Old May 22, 2026 | 06:17 AM
AL5461's Avatar
W221 S500
It makes it easier for undoing the screws that hold the switches in place.
Put another way, do you really want to risk dropping small screws into the steering column?
FYI, Amazony sellers of aftermarket Chinesium may not be exactly forthcoming in accurate installation information.
Yes the covers pop off, but having broken half the clips the new ones definitely won't fit or stay put. Take the switch out as a unit and strip and clean it carefully and refit it... Net result is functioning switches that look good and functional correctly without having to buy stuff that's just going to be disappointing.
Old May 22, 2026 | 06:20 AM
AL5461's Avatar
W221 S500
1. Absolutely. And without them the switches will basically become unusable.
2. Let that be a lesson. For the work involved, you should have stripped, cleaned and reassembled the originals that didn't rattle.
Old May 22, 2026 | 06:22 AM
AL5461's Avatar
W221 S500
Just because you can, doesn't mean you should 😉
