Wheels & TPS
Old Jan 8, 2026 | 08:29 AM
427Galaxie's Avatar
2013 S550
Wheels & TPS
Hi. I found a set of w222 20" wheels local from a 560. I was going to grab them for spares as I was going to have my AMG wheels restored. Will the tire pressure sensors work with my '13 in these W222 wheels?
Old Jan 8, 2026 | 09:25 AM
EasyPhil's Avatar
2007 S550 4Matic 2013 S550 Base
As long as they are the correct frequency they will work. You have to check the part number of tire pressure monitors.
Old Jan 8, 2026 | 09:35 AM
427Galaxie's Avatar
2013 S550
Cool. Thanks. At 500 bucks for 4 of them with tires, I couldnt say no!
Old Jan 8, 2026 | 10:51 AM
vettebk's Avatar
2007 S600, 2007 Chrysler 300 SRT8, 2000 C5 Corvette, 2017 Mustang GT, 2023 300C, and a 2019 Lincoln
Good price!! The TPS sensors work on two different frequencies and you need to make sure they are the same as the ones you have. If so, you are good to go. Mount and run! If not, bigger but not huge hassle. Simply move the old sensors to the "newer" tires. No coding should be needed. I replaced a dead sensor, checked for the same freq. dismounted the tire, replaced the sensor, remounted the tire. Within 500 yards after restarting, car read the tire pressures and displayed all four.
Keep us posted!
Old Jan 8, 2026 | 12:29 PM
BOTUS's Avatar
S500
if you buy autel sensors - current models are either frequency and you can code the sensors to match the current ones in the old wheels - then you can use either set of wheels and they will just work
Old Jan 8, 2026 | 02:35 PM
427Galaxie's Avatar
2013 S550
These wheels appear to be from a 15-18 S class. They are 8.5x20" and 9.5x20"
The tires are 245/40R20 and 275/35R20
Is this the correct staggered set up to not harm my 4-matic?
Old Jan 9, 2026 | 11:01 AM
Senecat's Avatar
1983 Nissan Shltbox
Should be same frequency, which is 433mhz.
Amazon Amazon
Tire height calculator shows rears being a 0.1" difference, fronts being 0.7" difference.
With wear thresholds certainly considered in design, I wouldn't hesitate to run them while AMG's are in the shop.
Been meaning to do the same here, just too broke lately to have it done. There's a shop here in Tampa that will chemically strip, press-straighten, CNC face, and basecoat clearcoat for about $250 a wheel. Not bad in my opinion. Did you get a quote for yours yet?
I'm particularly fond of these triple five spoke wheels. They just fit for this car. They really nailed it with these. I do like the larger 20" five spoke for the 221 gen as well.
Old Jan 9, 2026 | 11:42 AM
427Galaxie's Avatar
2013 S550
https://www.amazon.com/dp/B079SBCV1K
Awesome reply. Thank you. Yeah, I ended up looking to see the difference, should be fine. There is a local place that straightens highline wheels. They are about 130 a piece. They also cosmetically do the wheels...however, they seem to be great at the straightening thing...not great at the paint. So im going to have them straightened then powder coated separately.
Thank you!
Old Jan 9, 2026 | 01:40 PM
BOTUS's Avatar
S500
straightening alloy wheels - makes them soft and squidgy - heat treatment can re-harden but its a hell of a chore / skill to get them right
Old Jan 9, 2026 | 03:12 PM
427Galaxie's Avatar
2013 S550
I figured as much. I am not a wheel guy at all.... The person I am using I had fix a set of Bentley wheels for a customer. That worked out, will see what happens with these.
Im going to bolt these w222 wheels up this weekend and get the AMGs squared away.
Thats why I figured grabbing these as a 2nd set either way wasnt a bad idea just in case.
Old Jan 9, 2026 | 06:59 PM
Senecat's Avatar
1983 Nissan Shltbox
Absolutely, especially at $500 bucks. That's a damn steal and now you have four spares/winter set! Doesn't get better than that. You will have to post pics once you mount them up though, you're probably the first to have this car/wheel combo!
Old Jan 9, 2026 | 07:29 PM
Arrie's Avatar
Front tires diameter: 245 x 0.40 x 2 + 20 x 25.4 = 704.0 mm
Rear tires diameter: 275 x 0.35 x 2 + 20 x 25.4 = 700.5mm
704.0 / 700.5 = 1.005
You are perfectly fine with this setup, other than in my opinion it is UGLY. There needs to be more rubber on the rim in my opinion... But that's just me...
Old Jan 9, 2026 | 07:39 PM
427Galaxie's Avatar
2013 S550
Yes, Im headed to my shop to button some stuff up tomorrow. I may throw them on. Will snap a picture if I do!
Old Jan 10, 2026 | 11:25 AM
427Galaxie's Avatar
2013 S550
I put them on to get my AMG wheels repaired this month. Smooth ride, no issues...perfect for $500 marketplace find!
Old Jan 10, 2026 | 11:28 AM
Senecat's Avatar
1983 Nissan Shltbox
That's a nice pairing, actually! Looks good!
Old Jan 10, 2026 | 11:56 AM
427Galaxie's Avatar
2013 S550
Funny enough, I don't mind them. I was pleasantly surprised that the TPS had the same frequency and all was good.
Old Jan 10, 2026 | 01:06 PM
Arrie's Avatar
They look a lot better installed than by themselves. Looks like there is enough rubber on the rims.
The only thing is that it makes people think the driver wears a Top Hat😂
Old Jan 10, 2026 | 05:59 PM
427Galaxie's Avatar
2013 S550
Thanks. I wasnt very sure how it would look. Im okay with it.
Old Jan 11, 2026 | 01:36 AM
BenzV12's Avatar
W212 FL
Nice job, I like it as well
Old Jan 13, 2026 | 06:56 PM
427Galaxie's Avatar
2013 S550
I may get a top hat now!
Old Jan 13, 2026 | 08:13 PM
Arrie's Avatar
Post Pics!
