W221 2013 S350 – KEYLESS-GO Not Working After Replacement Key (IYZDC10 vs IYZDC11)
Old Mar 8, 2026 | 02:33 PM
PoliteGesture's Avatar
2013 Mercedes Benz S350 W221 OM642 TurboDiesel BlueTec 4MATIC
Hi everyone,
Before posting, I want to clarify that I have already searched MBWorld extensively regarding W221 KEYLESS-GO replacement issues and reviewed multiple discussions, but have not found a clear answer specific to my situation and my vehicle. Therefore, I am hoping to get input from members familiar with late-model W221 FBS3 systems.
Vehicle:
2013 Mercedes-Benz S350 BlueTEC (W221)
Factory option 889 – KEYLESS-GO
VIN available if needed
Original key (lost):
• FCC ID: IYZDC10
• Full passive entry operational
• Door handle unlock worked
• Push-button start worked without key insertion
(Photos of the original key are attached for reference.)
Replacement key supplied by the dealership:
• Part number: 204-905-11-04-9999
• FCC ID: IYZDC11
• Remote lock/unlock functions correctly
• Passive KEYLESS-GO does NOT function
• The vehicle now requires key insertion to start
The dealership provided the following written explanation:
“Unfortunately, Mercedes-Benz no longer supports that feature; the keys for the Keyless Go option are no longer available. As of right now, the keys for the Keyless GO option are no longer available.”
I am trying to determine whether this is:
• A true parts supersession issue
• A hardware revision difference between IYZDC10 and IYZDC11
• A low-frequency (LF) antenna limitation in the replacement key
• Or a coding/configuration issue within the EIS/FBS3 system
I hope you will appreciate the fact that I have already paid a considerable amount for the dealership-supplied key, and it does not restore the full KEYLESS-GO functionality my vehicle originally had. I am understandably trying to avoid repeating that expense without fully understanding the technical cause. I am looking for a reliable and independent Mercedes-Benz locksmith who can provide a replacement key fob that restores complete factory functionality and am seeking someone knowledgeable who can provide that at a fair and reasonable cost.
Technical Questions:
  1. Is there a confirmed hardware difference between FCC ID IYZDC10 and IYZDC11 affecting passive entry functionality?
  2. Has anyone with a late W221 successfully restored full factory KEYLESS-GO after losing the original key?
  3. Are there reputable independent specialists capable of supplying/programming a genuine KEYLESS-GO capable key without replacing control modules?
  4. Could this realistically be a coding issue rather than hardware?
I am located in Central California but willing to travel if necessary for the replacement KEYLESS-GO fob.
I appreciate any technical insight from members experienced with W221 KEYLESS-GO and FBS3 systems.
Thank you.
Photos of the original key, which I lost, are attached for reference:
