Airmatic question
Old Mar 19, 2026 | 08:08 PM
RichDMB's Avatar
2008 S550
Airmatic question
2008 S550 with 135K miles and it's not smooth over bumps. I feel a lot of the imperfections from the road and know that the ride should be better. The ride height is fine; back in the Fall I had to replace the level position rod in the rear of the car and had someone with the Xentry get the level right, and the car height looks fine. The shocks don't deflate after a couple days, the height stays fine. What else could cause this rough ride?
Old Mar 19, 2026 | 09:53 PM
Max Blast's Avatar
NGL450 w/EORP, S550
Worn out shocks mostly, but maybe you just have bad tires.
The air springs are just that, springs and they don’t do much to dampen the road forces you feel.
Old Mar 19, 2026 | 10:02 PM
RichDMB's Avatar
2008 S550
Brand new ContiPro's in November so it's not the tires. As for the shocks, what could be wrong as the ride height is totally fine and they don't sag after a few days? I'm pretty sure all the Airmatic shocks are original, but it would be pricy to just randomly replace all four corners.
Old Mar 19, 2026 | 10:53 PM
Max Blast's Avatar
NGL450 w/EORP, S550
you’re confusing shocks and springs. Airmatic refers to the air springs, sometimes also called airbags. .
The airbags act as springs. They are paired with a gas shock that has dual valving modes to either give you sport or comfort setting. This is ADS, for advanced damping system in long form. If this shock is worn out, your car is gonna be all over the place and the ride will feel weird and bouncy.
Your air springs seem to be fine and not leaking, but if they for some reason leak under use, it is possible you’re riding on the bump stops and that would make the ride feel extraordinarily rough. But I don’t think that’s what’s going on here.
Old Mar 19, 2026 | 11:09 PM
RichDMB's Avatar
2008 S550
You have me confused. If the airmatic isn't leaking, then what "gas shock" are you talking about? I thought these expensive Airmatic shocks at $1800 a piece were the shock and spring all in one.
Old Mar 20, 2026 | 12:15 AM
EasyPhil's Avatar
2007 S550 4Matic 2013 S550 Base
Spring plus adjustable damping = Shock Absorber Unit = AirMatic Shock.
Old Mar 20, 2026 | 05:02 AM
AL5461's Avatar
W221 S500
The struts have two or three components to them:
1. The air bag, as said, this is the spring part.
2. Top mount. These separate the shock red from the body.
3. Shock absorber. This does the damping. And they can fail.
4. Possibly optional, the adaptive damping valves.
The adaptive damping valves can be dismantled and cleaned, not unheard of for the wiring to have issues in the valve body.
Otherwise it's a new strut.
Old Mar 20, 2026 | 05:10 AM
BOTUS's Avatar
S500
I expect 18 year old suspension airbags are almost rock hard - add in dampers that are less then they once were won't help
I have been recently driving mine with a lot of pressure in the tyres and in sport and the ride is totally shocking
Comfort setting and 22 PSI in the tyres and it almost has some ride comfort - they biggest shock is getting in my fathers 2006 E class with 120k miles and steel springs - it has a beautiful blend of handling, compliance over potholes, great ride comfort, and fun that my S class has never ever had
Old Mar 20, 2026 | 06:19 AM
smiles201's Avatar
2023 E 450 Sedan. 2018 GLC 300. 2013 E 350 Coupe (retired)
Sorry. But it sounds expensive to get a good ride quality back. I imagine that there are alot of rubber bushings worn out too, and you might consider having that evaluated with any of the spare change you may have left in your pockets.
Old Mar 20, 2026 | 09:38 AM
Senecat's Avatar
1983 Nissan Shltbox
New/reman struts aren't expensive anymore. And they are easy to replace. These are old cars now, especially yours. $600 on eBay will get you all 4 corners replaced. There are a ton of other sources and the price goes up from there.
https://www.ebay.com/itm/18601087293...Bk9SR_CiprehZw
These are our struts exactly. Nevermind the audio (it is good for a laugh though).
Old Mar 20, 2026 | 12:36 PM
AL5461's Avatar
W221 S500
22 psi is borderline dangerous 🤯
That said so is running the incorrect tyre size for the wheel.🤐
Old Mar 20, 2026 | 02:21 PM
doni01's Avatar
2013 S550 4MATIC
It seems to me as the car has gone into a safe mode. So when the car senses a leak or any abnormalities it puts itself into the safe mode aka Harsh Ride. I chased the same thing with my W220 and trust me I changed shocks, tires, control arms you name it. So do not listen to the shocks being old etc these shocks either leak air or they don't. They just don't change to a hard ride overnight. What helped me was a Ride Re-Calibration followed with an alignment afterwards at the dealership.
Old Mar 20, 2026 | 03:23 PM
BOTUS's Avatar
S500
cracked wheels are worse - and that’s the norm in the UK these days - seldom manage to reach 55mph these days, the fake traffic jams are so bad so it not a big deal
used to run 2.3 bar but then realised the fuel consumption was dropping to little more than just set the pump to run to drain and walk to get a bank loan - so I pushed it to 2.8 bar - but the ride is horrific
Old Mar 20, 2026 | 03:47 PM
Max Blast's Avatar
NGL450 w/EORP, S550
an ABC equipped car will do that, but airmatic no - it’ll just leak down and eventually, the compressor will burn out from trying to pressurize leaky bags.
that is very possible what BOTUS is saying a pair with hard rubber components, combined with worn out bushings, added to a worn out shock can create the feeling of a harsh ride.
Old Mar 20, 2026 | 05:41 PM
Max Blast's Avatar
NGL450 w/EORP, S550
But to clarify my initial input here yes the airbag and shock are all integrated into one strut unit. It’s possible that one or the other is worn out.
Old Mar 21, 2026 | 08:14 AM
doni01's Avatar
2013 S550 4MATIC
Old Mar 21, 2026 | 02:57 PM
Max Blast's Avatar
NGL450 w/EORP, S550
Right, but there’s no harsh mode. You have whatever psi is available in the central reservoir to keep the bags inflated via the valve block for as long as that lasts. Once the suspension is fully depleted, you’re riding on the rubber bump stops, and you bet that feels rough.
by the way, Google AI will straight up lie to you sometimes.
Old Mar 21, 2026 | 04:50 PM
doni01's Avatar
2013 S550 4MATIC
So I made up the story and Google is wrong. OK do a search on Mercedes Airmatic Stiff Ride and read the results. Not the AI results but the ones from from all the different forums. Below is my experience with the actual issue vs nonsense shocks depleted opinion 👍
https://www.benzworld.org/threads/c1...#post-17422445
Old Mar 21, 2026 | 04:53 PM
RichDMB's Avatar
2008 S550
Has anyone on MBWorld ever tried using those Chinese made shocks found on ebay for $600 for all four corners? I assume no warranty other than if it's dead out of the box. The labor alone to change all four units would be way more than the $600 so you don't want to do it more than once. I would do it in my younger days but my back won't allow that! Does anyone have an idea how many hours it would take for a good mechanic to swap out all four?
Old Mar 22, 2026 | 05:25 AM
BOTUS's Avatar
S500
I think if I ever bother I will go with these guys - I'd estimate 2 hours a corner going leisurely - or an hour if throwing it in and stealing the money
https://aerosus.com/mercedes/s-class/w221.html
Old Mar 22, 2026 | 05:26 AM
BOTUS's Avatar
S500
although they rob you guys twice over - ha ha
Old Mar 22, 2026 | 09:30 AM
AL5461's Avatar
W221 S500
Not as long as I have a hole in my ***.
I would rather buy a cheap car to get to work whilst I figure out a solution/save up for genuine. Did the same thing when the gearbox failed.
Fronts are probably an easy couple of hours a side. Rears will take longer because you have to remove the parcel tray to have any hope of accessing the top nuts.
Old Mar 22, 2026 | 04:55 PM
Arrie's Avatar
in my car I only needed to pop up a narrow strip from the parcel tray to expose the top end bolts and air connection for the struts.
Old Mar 22, 2026 | 05:02 PM
Arrie's Avatar
Fronts are easy. About one hour.
Rears are a “Bit**” because of the air connection is hard to undo and re-do. Other part of the job is also easy with proper tools. Hardest part is to force the lower control arm down to get the strut free from it when working on garage floor with the corner jacked up with the jack from the car. But doable. Perhaps an hour and a half.
Old Mar 22, 2026 | 06:29 PM
AL5461's Avatar
W221 S500
You're probably correct. I remember seeing the top mounts etc when I swapped out my non Isofix tray for an Isofix one. I had forgotten that the tray has a removable panel😉
