S-Class (W222) 2014-2020
iPhone 6 Bluetooth Connectivity Issue Resolved
Old Sep 28, 2014 | 01:47 PM
mlewicki's Avatar
2015 S550
I posted under a different thread (GPS) about a separate connectivity issue I had encountered with the iPhone 6 and Bluetooth (running iOS 8.0.2).
Update: I contacted apple today and spoke to a senior technical regarding the issues I had encountered with paring my new iPhone 6. The symptoms that I encountered were unstable bluetooth connectivity and dropped call.
In case you experience a similar issue, here's what I did the resolve the issue (running iOS 8.0.2):
  1. I cleared all bluetooth devices in the car
  2. On the iPhone 6 I went to Settings --> General --> Reset and selected "Reset All Settings"
  3. Once the iPhone 6 settings were cleared, I proceeded to pair the phone via bluetooth by selecting the option in the car that allowed me to pair the connection directly from the phone ... opposed to pairing from the car itself (where Mercedes first searches for the phone opposed to having the phone search for the MB Bluetooth connection)
After following these steps, I was able to connect to via Bluetooth and make several calls without any stability issues or dropped calls (something I was not able to do earlier).
If anyone has also encountered a similar issue, I hope this helps.
Old Oct 1, 2014 | 02:33 AM
Diesel Benz's Avatar
Thanks for sharing (although I'm not an iPhone 6 user).
Hopefully there will not appear some Android that needs the same procedure, first clear all existing BT devices from the car before using this new phone. One would end up to a loop if the family had both phones...
Old Oct 1, 2014 | 06:02 PM
mrapplegate's Avatar
S550
Be careful there is an iOS8 bug that deletes iCloud documents if you reset all settings. Use at your own risk.
http://lifehacker.com/ios-8-bug-caus...d-d-1640780326
Most Bluetooth issues with iOS8 will be fixed in the soon to be released iOS 8.1 release. Testers report the Bluetooth problems are fixed.
Old Oct 1, 2014 | 08:18 PM
AppleFan1's Avatar
2025 EQS580
This is great to know. I will be ordering the 4.7 inch iPhone 6 late this week from the local Apple Store.
Old Oct 4, 2014 | 10:46 AM
LovinMercedes's Avatar
2026 Mercedes CLE53A4 AMG Cabriolet and 2025 MAYBACH EQS680V4
I am using the iPhone 6 with IOS 8.02.
I was able to connect my iPhone and everything works fine except:
I can make and receive calls from my car and it all works great.
The only problem is when I am connected to the car via bluetooth and I make the call from my iPhone, the car calls through the iPhone but it does not activate the speaker in the car so you can't hear it.
If I initiate the call phone the car, it comes over the speaker perfectly. It is only when I initiate the call from the iPhone. The screen comes up on the iPhone and it shows the phone is connected to the car but it does not come through the speakers of the car.
This is on my W221. Not sure if that makes a difference.
Thoughts would be appreciated.
Old Oct 4, 2014 | 11:46 AM
Jason B's Avatar
W140 Mercedes S350, W221 S550 sport
There are issues with the Iphone 6's bluetooth. They are working on a fix from apple. This is why I wait a few months to upgrade - I hate bugs.
Old Oct 5, 2014 | 10:00 AM
DFW_Neal's Avatar
2015 S550 ordered
My connection works for calls, but doesn't read out messages. (I have iPhone 6) hoping sw upgrade will fix.
Old Feb 3, 2015 | 10:15 PM
Since I was 16's Avatar
350 CLK
go to this link to fix your iphone 6 bluetooth
http://www.mercedes-benz-mobile.com/...sa/index2.html
I have been on the phone with both tmobile AND apple--no one knew what was up.
for me, i had to hold the button on my blue tooth module in the center consol, enter the code and BAM. DONE. PERFECT.
Old Feb 5, 2015 | 04:03 AM
Wrong forum, these W222 cars do not have that BT module (European cars with the comfort telephony option may have one but pairing for those is different from what you explain).
With that BT adapter everyone needs to press the button and enter the code, just like written in the manual and as you have to do with every similar BT hands free device.
Pretty odd if nobody from Apple or T-mobile where able to help you even if the question was about the MB BT adapter.
Old Feb 5, 2015 | 02:46 PM
350 CLK
Oh man my bad! I was so thrilled to find somthing and get it online where there aren't answered anywherei did not note model numbers!
Old Feb 5, 2015 | 03:19 PM
No problem at all, happens to all of us (or at least me). Just wanted to clarify for future readers that in this thread we have discussed two different cars.
Old Feb 5, 2015 | 03:30 PM
350 CLK
I also write that in full sun and missed the typos!
