S-Class (W222) 2014-2020
Headlight Condensation
Old Mar 9, 2015 | 05:14 PM
pdeacon's Avatar
E450 wagon, C43 AMG Cpe, GLE AMG 63S
I know this subject has been discussed before (can't find the thread) but has anyone experienced condensation in the headlight enclosures? Noticed it this afternoon in one of mine. Is this a defect? It appeared along the bottom edge and is about two inches wide. Only drove the car for a short distance without headlights so don't know if it will clear itself.
Old Mar 9, 2015 | 05:33 PM
emilner's Avatar
S560
It's considered normal. I've had it and it is mentioned in the manual. Personally, I think it's BS that a $100k car gets condensation in its headlights....
Old Mar 9, 2015 | 06:55 PM
pdeacon's Avatar
Thanks...I agree it does make you wonder.
Old Mar 10, 2015 | 09:26 AM
W222S's Avatar
X253 GLC3004M, 222 S400, Ferrari Roma, Tesla Model S
You can use toothpaste to clear the headlamps, if I'm not wrong.
I read it somewhere.
Old Mar 12, 2015 | 02:59 AM
Diesel Benz's Avatar
Yes but it is a bit difficult to reach the inside with a toothbrush.
Actually the toothpaste solution is for the case when the outside surface of the headlamp is worn out and dimmed. This was about condensation inside the headlight, it is just the moisture that would need to be removed.
Old Mar 12, 2015 | 03:26 PM
marthyh's Avatar
S500
+1
Old Oct 13, 2015 | 05:28 PM
wows500's Avatar
2015 S550 4matic, 1960 Chevy Impala Conv, (Previously 2002 S500, 2008 S550 4Matic)
I picked up my new 2015 S550 2days ago and noticed the condensation just as everyone is complaining. I took the car to the dealer and complained about it and was told that Mercedes has a new solution and I have to leave the car as parts have to be ordered from Germany. I asked what the solution is and was told that the headlights have to be opened and some kind of a gel has to be inserted which will absorb the condensation.
I called today and was told the parts arrived and they have to open the headlights from the front and also remove the front bumpers to do this as they are following the instructions given by Mercedes.
I will get the car back tomorrow or on Thursday and see if this will work to remedy the condensation.
Old Oct 13, 2015 | 05:36 PM
LovinMercedes's Avatar
2026 Mercedes CLE53A4 AMG Cabriolet and 2025 MAYBACH EQS680V4
No thanks.
Old Oct 14, 2015 | 09:44 AM
Streamliner's Avatar
Originally Posted by LovinMercedes
No thanks.
My Panorama Roof creaks sometimes. To "TRY" and remedy the problem, they say they need to remove the headliner. Being very particular, I foresee "messiness" with such a procedure, so I told them to forget it.
Old Oct 14, 2015 | 09:56 AM
MTrauman's Avatar
'25 S63 AMG E Performance, '26 CLE 53 AMG
"Messiness"? WOW you are politically correct. My point is the same but not politically correct. Every time I take my car to the dealer--being particular--the dealer screws something up. So my policy is take it to the dealer minimally for the very important things.
When I took my '14 S550 to the dealer to get the seat leather replaced due to a defect, they scratched the rear quarter panel.
So when I picked up my '16 S550 about 4 weeks ago and got it home with 32 miles on the odometer I noticed the condensation in the headlights. I will live with condensation--period. Recall that MB does say this is "normal". Not sure I agree with that but I will live with it.
I don't want to just pick on MB dealers. I have a 2012 Ford F150. The last time I took it to the dealer for a warranty item, they put a nice door ding in the door.
Bottom line--keep the cars away from the dealers as much as you can or suffer the issues that seem to occur when you have people handling your expensive cars that don't really give a "rip".
Old Oct 14, 2015 | 10:11 AM
tommyr's Avatar
25 GLE53, 24 Macan, 15 GLK350
Here's some insight. We make LED lighting for a variety of applications (but not for Mercedes). These S550 headlights are, by design, not a sealed unit. The LED unit generates heat, and as a result of not being sealed, as they cool the air inside the headlamp cannot hold moisture and the result is water condensation. This is more noticeable because of the way the reflectors and lenses in an LED headlamp assembly are produced (simply put, much higher clarity and surface prep). There is no optical or electrical downside to the condensation.
I can look at my headlamps and see condensation at times. I choose not to look for it. ;-) And I've never had anyone else point it out to me.
Old Oct 14, 2015 | 10:14 AM
We certainly agree. Just about the only marks on my 2004 SL500 came from dealer servicing. As for "messiness," I've been doing a lot of ranting & raving as of late, so I was trying to be nice.
Old Oct 14, 2015 | 10:35 AM
When I had an issue with one of my cars, and had to take it to a body shop, I saw several cars from the nearby MB dealership.
They told me one would not believe how much money they get on an annual basis to fix the brand new cars from the MB dealer.
If they don't care about their own cars, I can imagine how little they car about others.
Old Oct 14, 2015 | 04:42 PM
Jason B's Avatar
W140 Mercedes S350, W221 S550 sport
So, what did you do about the door ding, or the scratched quarter panel. Did the dealer take responsibility when you told them, and did they fix it?
Mine just dented my driver side lighted door sill. It's not a band dent, but the point is, it wasn't there when I dropped it off.
BUT, doesn't that condensation, over time, make the lights look spotty on the inside? Like a window that was rained on, over and over?
Old Oct 14, 2015 | 05:44 PM
MTrauman's Avatar
Door Ding at Ford Dealer--Did not tell them. Very long story to this situation but here goes.
Purchased new 2012 Ford F150 in 2012. Rear Window Defogger never worked from day 1. Took it in for seemingly an easy fix--atleast one would think. Ford denied the warranty claim because they said I damaged it--BULL___! I figured out the dealer damaged the rear window and the dealer and Ford denied the warranty claim. I was so PISSED OFF because either the dealer or Ford damaged it and did not stand behind their vehicle. Two months after the dealer and Ford denied the warranty claim with less then 100 miles on the odometer, the dealership was sold to a new owner--I wonder why. Well the dealership was a A hole (sorry for the French words). So just before the warranty was up at 36 months, the new dealer got the window fixed under warranty (new dealer was better even though I dealt with the exact same employees). So I thought the dealer was great but I got the truck home and they dented the door in their parking lot. I had a new rear window with an operable window defogger but a dent in the door.
I then proceeded to take it to Dent Wizard myself and got the door ding fixed for $150. I did not want this dealer touching my car after that three year BS on the rear window defogger. Still have the truck and the dealership is a good dealer after they purchased the dealership from the prior A hole dealer.
MB dealer scratching the rear quarter panel. I decided to take care of this myself with the MB touch up paint and my mechanical orbital buffer. These dealerships do not even know how to use a buffer on a new car since my '14 and my '16 S550 came brand new with swirl marks in the paint. So when I buy a new car I buff it myself with my orbital buffer to get their swirl mark scratches out of the paint of the brand new cars. Again, do not want anyone touching my car that gets paid $7.50 per hour to simply scratch my paint with their buffer equipment they do not know how to operate. With all that said, I love my MB dealer but I want to keep the car out of their hands since their lot people do not give a Sh-- about their customer cars.
Old Oct 14, 2015 | 05:54 PM
dbldpr's Avatar
Veteran: Navy
Had condensation on only my wife's car. Took headlight off. Blow dried the inside then installed glue all the way around the seam. Then applied clear silicone caulk around the seam. Have not had a problem since.
Old Oct 14, 2015 | 08:53 PM
This is probably a bad idea as I have been told you can't block the seams as the lights need to breathe.
Don't know for sure, but I was told that by someone that should know.
Old Oct 14, 2015 | 10:15 PM
dbldpr's Avatar
Veteran: Navy
This was done 4 years ago and no problem so far
Old Oct 14, 2015 | 10:17 PM
When I was speaking to the MB tech we were talking about post 2014 headlamps, so maybe something has changed.
Like I said, I really don't know.
Old Oct 17, 2015 | 07:13 PM
wows500's Avatar
I got my car back on Wednesday and today is Saturday. So for the last 3 days I have not noticed any condensation. Inserted pictures took today and the headlights are clear. They installed folding baskets W/Desiccant packs and also installed Membrane which was supplied W/Baskets.
Will wait and see if the condensation comes back or not but for the time being it seems it is working.
Old Oct 25, 2015 | 02:49 PM
wows500's Avatar
Thumbs up Update on condensation
Well it is almost two weeks now and I have not noticed any condensation on the headlights. Today it rained and I was wondering if it will come back NO it did not happen. So the folding baskets W/Desiccant packs and the Membrane worked .
I am happy with the outcome as it was more of an eyesore and did not like the look of the gleaming headlights with the foggy appearance.
Old Oct 25, 2015 | 03:12 PM
WEBSRFR's Avatar
Tesla Model S P100D
I've had issues with the panorama roof creaking and I suggest that you let the dealer fix this for you while the car is still under warranty. Whatever they take out, they will put back in and if it introduces new creaks (which I doubt) they will address that. The panorama roof creaking is horrible to deal with if you have sensitive hearing and they can fix it and completely make it go away.
Second time I developed this noise, they were able to fix it with a special lubricating solution that did not require they dismantle anything.
Old Oct 25, 2015 | 08:19 PM
RJC's Avatar
RJC
Various
Glad to hear this.
Old Dec 11, 2016 | 01:54 AM
Nice Ride's Avatar
2014 S550 AMG, 2017 XT5
Can you see the folding baskets or modifications from looking into the light assembly? For a second I saw 2 black boxes in the lower portions of both lights, then realized it was your Leg reflection in the photo. What was the build date of your car?
Old Dec 11, 2016 | 08:21 AM
Jason B's Avatar
But, doesn't this condensation over time cause water marks inside? Like when rain dries on windows???
