S-Class (W222) 2014-2020
2015 s 550 coupe headlights/high beam assist
Old Jul 29, 2015 | 10:07 PM
venture's Avatar
2015 S 550 4 Matic Coupe
I can't seem to be able to turn on the high beams manually. I leave the lights in the auto settings. The high beam assist works and I can flash the high beams. But the stalk doesn't move beyond the resistance point like it's supposed to to turn on the high beams. What am I missing here. Help.
Old Jul 29, 2015 | 10:18 PM
Wolfman's Avatar
Super Moderator
Isn't that normal behavior?
Pushing the stalk forward means high beams are on. If you want to have them automatic, you leave them in the forward position and enable automatic high beam in the instrument cluster menu.
Disable it and you have your manual high beam.
Old Jul 29, 2015 | 10:42 PM
venture's Avatar
I have to push the stalk forward and hold it there to keep the high beams on. I just went for a drive again. Same thing. Manual says push backwards past the resistant to turn on high beams. But there is no past resistance point. ?? When I'm on a dark neighborhood street I want to turn on my high beams and keep them on with out holding the stalk forward. I'm still not understanding this?
Old Jul 30, 2015 | 08:26 AM
jbattan's Avatar
2023 Mercedes EQS 580 SUV, 2023 Bentley Bentayga, 2023 Genesis GV60
Turn the rotary switch from A to On and then the high beam stalk will work as you want.
Old Jul 30, 2015 | 08:30 AM
venture's Avatar
I figured that out this morning. Thanks for the answers. This works totally different than Audi system on my 2014 A8.
