"360 [degree] camera unavailable"
2015 S550 Palladium/Deep Sea Blue, 2016 Tesla Model S 70D, 2015 Volvo XC70
...it's a message I sometimes get on the screen instead of the normal surround and rear views. It happens maybe a few percent of the time when I startup and shift into reverse; later in the same drive, if I am going slow or stopped and manually engage surround view, I'll still get the message and no camera view. But after I park, then the next time that I start up again, it will typically be working normally.
Has anyone else run into this? I guess I'll take it in to the dealer, but since it happens rarely they are going to have a problem duplicating the issue.
2017 GLC300, 2015 S550 4Matic LWB
Happened to me once so far.
!["360 [degree] camera unavailable"-pw7fvtv.jpg](https://mbworld.org/forums/attachments/s-class-w222/444499d1683252108t-360-degree-camera-unavailable-pw7fvtv.jpg)
I turned off the car, turned it back on and it still had the camera unavailable message. So I drive off at low speeds through the neighbourhood, and even when I tried it after a few hundred meters, it still had the error message. Again I drive off, then when I was stopped at the next stop light after a few minutes, I hit the 360 camera button on the left and it worked![nix](https://mbworld.org/forums/images/smilies/nixweiss.gif)
That's the problem with all German cars, each and every single model of car has a different camera module & programming. So there's bound to be bugs. Unlike Toyota, one camera module, and only one way to activate the camera across their entire line up.
Sounds like MB has figured this out:
Complaint When reverse gear is engaged or when the 360° camera is activated manually via the function bar in the cockpit, the 360° camera system may show no image in the COMAND display.
The fault message "360° Camera System Unavailable" appears in the COMAND display.
Cause Software
Remedy Program 360° camera control unit (N148) with new software.
The new software is available with XENTRY DVD 03/2014 and add-on 3644 or with XENTRY DVD 05/2014 and add-on 3667
Cause Software
Received 4,435 Likes
'71 Pinto
Reference bulletin LI54.65-P-059552 https://mbworld.org/forums/new-s-cla...ml#post6132526
'71 Pinto
Bulletin released 8/6/14 covering production date 7/13 to 2/14 nevertheless, since malfunction is intermittent mentioning bulletin and requesting shop foreman get involved should circumvent “no trouble found” and hopefully resolve the matter.
