Garage door opener failing
Hello guys and gals,
I have a 2018 S560. I have to reprogram my homelink button for my garage door every week or 2. I have never had any issues with previous cars and have 2 cars controlling the garage door opener now. The garage door opener is Liftmaster with rolling code. Very frustrating. Any ideas? Dealer is clueless. Thanks.
Wolfman (03-07-2018)
Super Moderator
Received 3,319 Likes
I have an appointment for our fixing/replacing our garage door opener. It's a 2018 E63s but it's using the same updated opener. Since we bought the car 3 months ago I had the opener "forget" the door we used most commonly 3-4 times. Just stopped opening the door. The other two doors worked normally. This happened on two separate doors; the other MB's work fine.
Process was to erase and re-program all three door which only takes a minute or two. Our openers are late model Chamberlain openers with MyQ which happen to be the same product as Liftmaster.
Interesting Wolf. I use all 3 of my homelink buttons in all of my vehicles. One for my primary home, one for lighting control in the house and the 3rd for my 2nd home. The issue is with only the 3rd button, controlling the garage door on my 2nd home, which uses a less than 2 year old Liftmaster with rolling code and myQ. As I said before, it will fail to open this door after a few days or week. None of our other cars have this issue.
I have not started from scratch yet, erasing all the homelink buttons yet. You can erase each individual button, and reprogram each one, which is what I did. I think I will try what you did, erasing all and reprogramming. If I understand you, that did not work though? Thanks
Super Moderator
In general, the new mirror/opener looks better and the opener has dramatically better range than before. Before your post I thought it might be just a faulty opener but it could also be a random bug with the Chamberlain/LiftMaster openers. I have experienced that occasionally even the handheld Chamberlain remotes loose the link to the door opener and need to be re-linked via the wall switch.
I just reprogrammed all buttons and will see what happens. I really don’t think that the issue is with the Liftmaster, since we have 3 other cars that have never had this issue. My 2015 S550, which I traded for the 560, never had this issue either.
Super Moderator
Same here with the other MB's but am at this point looking for anything that's unusual. Could be a firmware issue on the new opener. Definitely not anything physical.
15 MB Sprinter, 14 MB S550, 08 Smart Fortwo, 04 Dodge Sprinter, 87 MB 190E 2.3-16
My fix was to replace the LED/fluorescent bulbs I installed on garage opener with standard incandescent. Works now from a distance and consistently, before I would have to be really close and press many times and many times unsuccessfully. Supposedly LED/fluorescent bulb emit a frequency that interferes with unit.
Super Moderator
Carfan500 (03-07-2018)
2018 S560 and 2019 E450 Wagon.
Interesting. I have a 2015 S550 and a 2018 E63 AMG and no problems opening and closing my lift master garage doors. I have an old sears door opener up north and that seems fine too.
18 MB S63, 2022 911 Turbo S, 23 BMW M5C
Here's what it looks like in the garage. I don't even use the lights in the Liftmaster as they never worked right. I only use the garage ceiling lights on motion detectors.
