Maybach Eating inside edge of the tires
I took the pressure of the tires up to 47 on all corners and we drove from Florida to Atlanta last weekend. When we stopped for gas I would run my hand across the tires from side to side. They were simply warm uniformly.
Perhaps the person that suggested raising the pressure was onto something. By the way the car drives no different in normal driving.
I run my tires at 38 PSI. Recently, the wife and I did a 5,000 mile trip from Austin to Berkeley and back over 2 weeks and averaged 24 MPG in the S600.
I would be under the notion that 47 PSI is probably a bit too high, you should get similar low wear and similar mileage and slightly better ride closer to 40 PSI than 47 SPI.
The problem is the car even with factory alignment will eat the inside sidewall of the rear tires and cause a total failure. In 50,000 miles we have had two failures like this. The tire tread is still in great shape but the sidewall is torn up. The first thread for this issue is here.
https://mbworld.org/forums/new-s-cla...ear-tires.html
Taking some recommendations from some very informed people in the previous thread I decided to try a higher pressure which supposedly makes the center line of the tire take more of the load of the car. As I said earlier I ran my hand across the tires and felt no hot spots when we would stop for gas.
There is nothing more annoying than to be driving along and get the message tire failure........... Had it twice............ NOT fun. It also sucks to spend close to 1000 dollars on two tires that look like they are in great shape but this sidewall failure happens......
1: The S class as heavy as it is ( about 5,500 pounds ), the tire wear should be on the outer tires and not inner tires. Like a member mentioned here happening on the E63 which is what I also saw on my previous E63s which is very common on the W212 AMG E63 forum.
2: With the OEM continentals, Michelin and Pirelli tires which is a softer compound taking corners even making a U turn at any speed high or low, the outer tires gets worn out fast because it is such a heavy car when taking a turn pushes the outer tires to its limit.
3: If you are using a harder compound tires, the car will drive rough, but tires gets worn out slower, but that is the trade off using harder tires.
4: Dealer recommended cold 48 pounds inflation.
Hope this help.
The car has the OEM tires and I was running the pressure at what the car labels say to but was having tire failures where the inside sidewall of the rears were being eaten away and of course the tire fails. Of course the rest of the tire being the treat part is in great condition................ I learned adding pressure gets more contact pressure added to the center of the tire and as I stated it seems so far to have helped keep the sidewalls from getting hot.......
FYI assuming proper alignment, over inflation will accelerate center tread wear and under inflation will accelerate edge trend wear.
Also, camber and toe are apple and orange but improper settings for either can give you similar wear patterns of the other.
Good luck
1. A tire's maximum inflation pressure is the highest "cold" inflation pressure that the tire is designed to contain. So 47 psi is ok but will reduce comfortable level. Ok as a work around till the issue resolved.
2. do you use oem wheel ? looks to me that the wheel/rim offset is incorrect, offset number too high
3. do you use oem tires, if rft, do you use MOE tire recommended by MB? Need "XL" Load Range to handle the load.
4. any scratch markers on the suspension components where eating the tire ? Must have. Dealer service should find some and it may be bent or damaged
hope you can solve the issue soon. Any normal car should not do this.
I dont know if anyone else has had this problem with any W222 cars but if they have then what I did COULD be a way to fix the problem. As I said the car rides exactly the same as it did with the factory tire pressure.
Another possibility is that the car got wrong disk from factory so the offset is off. Taking wheel off and check the part number on the disk and make it is for your car. You really should check with dealer and MB to resolve issue.
So we have had THREE rear tire failures in 50000 miles and every time the inner side wall literally is eaten away and has holes in it and you loose your tire pressure. The rest of the tire looks great.
So as stated earlier I did one of the simplest things and that was to add pressure to the tires and as I said the car rides exactly the same as it did before. The tires did not have any hot spots on them when we stopped to get gas. I have a feeling that this MIGHT solve the problem.
Katie
The manufacturer specifies pressures that allow the tire to perform safely up to its speed limiter setting while assuring the car will understeer when pushed to its limits. The S65 has four recommended pressures for the rear tires depending on planned use. Two people, no other load and not in excess of 155 is 33psi rear. Same but with 4 passengers and maximum load is 39 psi. When I plan to carry 4 people plus luggage on a trip I raise the rear tires to 39 psi but that rarely happens. For anticipated driving at the 186 limit the rear pressures should be 44 or 51, depending on the load. I do not anticipate driving at that speed in the US.
I do not think a scan tool will pull the top speed limiter. I know most of the aftermarket tunes like Eurocharged and Renntech do if it matters. I do not drive anywhere near that fast on public roads but perhaps I get to a track and try it out.
I was at Laguna Seca over the weekend driving all the AMG fleet. A lot of fun but they make sure the maximum speed is under 100. I saw about 102 in both the GT-R and interestingly in the SL63, but the instructors keep a real close eye on you if you drop back too far and then run up fast on them.
the maybach is 99y
the gtc has the ( )
