W222 Moisture in Head Lights
Also with the headlamp assembly...is it a Can't or they just refuse to because they want to make more money having you replace the headlamp assembly as well?
This is truly fustrating....a $100k car, I only have 35k miles on it, and now the kbb value is about $22k, but to repair both headlamps...it will cost approx $10k or half the value of the car!
The unprotected HL electronic module located at the lowest spot where water accumulates is an unfortunate coincidence... sort of.
This is where a drain spout should prevent water puddling.
HELLA is a top HL manufacturer, they are not clueless.
FIND THE LEAKS + SILICONE THE HARNESS CONNECTORS.
Given the fact that Mercedes customers buy the complete automobile, as opposed to an assembly of parts, the headlight failures would fall back to Mercedes, not the manufacturer of the the headlights.
Has anyone reading this message become aware of a group of buyers who have instituted a a lawsuit based upon these headlight failures ?
1) MB will not take responsibility for their defective headlamp and their even more defective desiccant bag solution which lead to headlamp failures.
2) Since MB will not take responsibility - only recourse is for owners to repair this themselves.
3) Headlamp assembly is fine, but only the Voltage Converter Module is bad and needs to be replaced? Or do both "Voltage Converter Module" + "Control Unit" need to be replaced?
Can someone please confirm the above?
It's built to fail specially unprotected module at the bottom where water is forced to accumulate.
It's an modern "open concept" without any protection or drainage.
Is this not solved as of 2025?
Should I be OK replacing just the LED module? Does it need to be programmed if it is used? They're not too expensive and certainly WAY cheaper than a headlight.
Frankly I don't care too much about the condensation, but I absolutely don't want to be replacing expensive modules.I'd be fine with just sealing the hell out of the modules and calling it a day
Replacing just the LED module is the right move. A used one should work without programming. Before installing it, you must fix the condensation. Seal the headlight housing or the new module will fail too. Check the headlight vents aren't clogged.
I've been looking at these:
Pair of Headlight Lens Cover Shell For Mercedes-Benz S550 S600 W222 2014-2017 | eBay
I found this video, but I am not sure if it would work for the pre-facelift models (like mine):
All of my electronics work, however my lenses are mildly pitted and show old condensation "drips" on the inside of the lens. I recently purchased the car (last week) and I am in the process of "reconditioning" some items to bring the car to its proper state. I'm not afraid of baking the assemblies for a bit to remove the old lens and install the new, but I am trying to verify if these will work, or if it's been successfully done.
Knowing that replacement lenses will not last nearly as long as OEM, I would plan on protecting them with UV PPF.
Thanks in advance!
Hi Ryandi,
I cant PM you because your post count is too little. You can't PM me too, for the same reason.
Sorry, I wont show my personal email in open forum.
Why don't you pass me your email instead ? Make a one time email or temporary email..... will be better.
Later....
Appreciate your quick response.
Here is my temp email address : birewof791@helesco.com
Looking forward to your email.
Thanks.
Ryandi
Thanks.
Ryandi
DONE
