S-Class (W222) 2014-2020
FINALLY fixed the common TRANSMISSION rough up/down shifting in W222!!!!!!!
Old 05-09-2024, 05:52 AM
  #176
SPONSOR
BenzNinja's Avatar
WWW.BENZNINJA.COM
Originally Posted by epnfrn
Fyi my dealer has been very unwilling to do this on my 2020 S560. The shifts absolutely drive me crazy. They are saying there may be a software update in June, though I’m skeptical.
Others have posted about success doing this themselves with Xentry. I’ve tried to do it but can’t figure out how. I’ve asked others to share step by step instructions and no one has been willing thus far - though I realize it is a lot to ask. BenzNinja has offered to try figuring it out but I haven’t had a chance to connect with him yet.
good luck and keep us updated.
We provide this service only for members (it's free as all other repairs) and all our services are the same as the dealer + much more
BenzNinja service has been certified by MBworld and Workshop users over 6 years with a 100% 5 star rating. Thousands of reviews.
With BenzNinja you can do the same "manual" (some call it forced) adaption with you driving and a friend holding the laptop
there is no tech required.
Old 05-09-2024, 08:28 AM
  #177
epnfrn's Avatar
W222 S560, 991.1 4S, Rivian R1S, Honda Odyssey!
Still have a little less than 4 years left in extended MB CPO warranty. The head tech said he feels the rough shifts but that they are within spec.
Old 05-09-2024, 09:40 AM
  #178
SPONSOR
BenzNinja's Avatar
WWW.BENZNINJA.COM
even better!
Old 05-15-2024, 07:05 PM
  #179
1787's Avatar
2020 MB S560 4M, 2016 VW GTI 6MT
The dealer replaced the electrohyrdraulic controller unit. Fingers crossed that this actually fixed the problem. I'm still waiting on the car because they are also replacing the exterior window trim.
Old 05-15-2024, 09:55 PM
  #180
Streamliner's Avatar
Received 3,601 Likes on 2,061 Posts
2020 S560 Sedan, 2019 SL450, 2019 E450 Luxury Trim Wagon, '24 BMW I7 on order...
When I had this problem, they replaced the JOHNSON ROD. Unfortunately, it didn’t help, but it sounded like they were doing something.
Old 05-16-2024, 06:40 AM
  #181
W205C43PFL's Avatar
Received 2,492 Likes on 2,119 Posts
PFL205.064 with M276.823 (Oil pump solenoid defeated)
Hmmm, is it inside the transmission, what is the part number? How long was the job, if it is inside the tranny, I guess they did ATFas well?
Do you mind posting the work order, don't worry about it if you don't want to.
Old 05-16-2024, 11:01 AM
  #182
S_W222's Avatar
Last 5 years: S560, X7, X5, Accord; Sold:15'S550, 20'BMW X7; 19'BMW 530e; 20'Lincoln Navigator,LS460
let us know how it goes. I hope it works. While am not trying to scare you, personally I feel that this might not fix the inherent issue that most of owners are facing. To me, only the active force adaptation can fix (tech driving the car, computer connected, another tech in the passenger seat force-adapting all the shift points). This is already documented within the Mbenz service bulletins. Changing electrohyrdraulic controller unit may fix it for the first few days or 1-3 weeks for the first couple 100 miles, just like what a cheap coding/software reset would do. However, if the controller unit was truly damaged, that might fix it so let's see. Also, there is a chance that they have done force adaptation as a part of installing the new controller unit. In all case, keep the community here updated please, and good luck.
Old 05-20-2024, 09:52 AM
  #183
1787's Avatar
I forgot to scan the printout they gave me, but here is the description from the online portal of what they did. I will check the work order when I get home to see if there is any additional information on part # or description. They had the car for almost 2 weeks, which I imagine was mostly waiting on the part. So far, I do notice an improvement. I can still feel the 3-2 downshift being overly harsh, but not as frequently and not as severe as it was before. They are claiming that the transmission needs 300 miles to adapt to driving style, so fingers crossed, but I am skeptical and share the concern of S_W222.
Cause
Faulty electrohyrdraulic controller unit
Correction
Remove oil pan from automatic transmission, remove & replace electrohyrdraulic controller unit, install in reverse order. performed initial start up of electrohyrdraulic controller unit.fw Customer will need to drive 300 miles for valve body to adapt to driving style .
Old 05-20-2024, 10:16 AM
  #184
W205C43PFL's Avatar
Cause
Correction
Thanks! Did they did the ATF as a result of the work?
Old 05-20-2024, 02:25 PM
  #185
1787's Avatar
If you mean, did they change the transmission fluid, I would imagine so, since they had to remove the oil pan. But maybe I'm not understanding your question.
Old 05-20-2024, 02:28 PM
  #186
W205C43PFL's Avatar
Yes, that is it. I was curious and found it weird it wasn't documented they did that but they couldn't have reused the fluid anyways.
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
Quick Reply: FINALLY fixed the common TRANSMISSION rough up/down shifting in W222!!!!!!!
