RECALL - 2018/19 S560 - Oil Plugs
I was looking at a used 2018 S560 on a dealer's site and while looking at the free Carfax report it showed that there is an open recall on the 2018 & 2019 S560 models. There is an issue with the material of the two engine oil plugs, which could result in oil leaking out of the engine. You can go to https://www.mbusa.com/en/recall and enter your VIN to see if there are any recalls on your car.
MBUSA CAMPAIGN NUMBER - 2020030017
NHTSA RECALL NUMBER - 20V173
RECALL START DATE - Recall Currently Pending
RECALL REPORTED DATE - Mar 20, 2020
COMPONENT(S) - Closure Plugs on the Engine AA
SUMMARY - Mercedes-Benz AG ("MBAG") has determined that on certain Model Year ("MY") 2018-2019 S-Class (222 platform) and S-Class Coupe/Convertible (217 platform) vehicles equipped with 4.0L 8-cylinder gasoline-engines (M176), the material of two engine oil plugs might not withstand the high engine loads during driving.
The material of the closure plugs might fail to contain high engine oil pressures, which can occur especially during dynamic driving and could result in engine oil leaking from the plugs. The resulting oil leak on the road could create a potential road hazard increasing the risk of a crash for other road users. If the engine oil level were to fall below a certain limit, the driver would be made aware of this issue by a red warning message in the instrument cluster. if the warning message were to be ignored by the driver, the engine could run without the required oil, damaging the engine and result in a vehicle stall.
As a precautionary measure, Mercedes-Benz AG, via its Mercedes-Benz service partners, will rework the engine oil plugs on the affected vehicles.
My S560 is due for an oil change soon too... I take it that they will just remove the oil drain plugs, save the old oil into a jug, and pour it back into the engine?
I was told to not bring the vehicle in yet and stand by.
D.J.
My service advisor last week mentioned he does not have information on it either, so I'm left in the dark.
Anyone else have better luck with more information?
I was at my local dealer in Northern Va for my B1 service. I mentioned about the recall and they said that they still do not have a solution yet.
Remedy: Service Center will "reinforce the engine oil plugs by adding a retaining plate on the affected vehicle"
