S-Class (W222) 2014-2020
First small hiccup, 2020 S560 4Matic
Old May 10, 2020 | 02:31 PM
Todd in PA's Avatar
2020 S 560 4 Matic
deleted
Old May 10, 2020 | 09:09 PM
chassis's Avatar
2017 GLE350 4MATIC
deleted
Old May 10, 2020 | 10:45 PM
YasS's Avatar
W212 E400
That is very frustrating. Could it be the actuator?
Old May 10, 2020 | 11:28 PM
MBS63AMG's Avatar
2019 S560, 2022 Audi S8
Once in the car with door shut and the key on your person, does it consistently work properly with the interior switch? Just a question in diagnosing the problem.
Old May 10, 2020 | 11:43 PM
2012 merc amg's Avatar
2018 S560
Maybe there is some kind of film over the handle, I wonder if it would be worth it to wipe it down with alcohol wipes? I don't think that could do any harm? Might be worth a shot.
Old May 11, 2020 | 08:14 AM
Todd in PA's Avatar
2020 S 560 4 Matic
Deleted
Old May 11, 2020 | 08:19 AM
OnlyGerman's Avatar
Too many german broads
Just go to the dealer and have them replace the door handle, it is obviously something wrong with that keyless go sensor.....Why are you so afraid of replacing parts under warranty??
Old May 11, 2020 | 08:42 AM
Todd in PA's Avatar
2020 S 560 4 Matic
deleted
Old May 11, 2020 | 09:41 AM
OnlyGerman's Avatar
Originally Posted by Todd in PA
I posted this in my original post
"The next step is to replace the door handle, but as it is a painted part, I am reluctant to do so if they can't make an actual diagnosis as to what is the problem.
I am not a fan of just replacing parts, even under warranty."
Unfortunately for me I am one of those people who are extremely discriminating. I easily notice small defects and I don't want to look at two different colored door handles every time I look at the car! If the painted part of the door handle doesn't match exactly, it will really disappoint me. That being said, w/o a proper diagnosis of the problem, replacement of the handle might not fix the problem and instead make it a bigger problem for me.
So far no codes are stored. I thought it might be a loose connection in the connector between the chassis and the door where the hinge is up front, but again, no codes.
As a retired health care provider, I was a diagnostician by profession. You really need to identify the problem in order to get the correct treatment, otherwise you don't get well.
I was just hoping that someone might have some insight here on the forum to help with the diagnosis. If this keeps up, I will proceed with the door handle replacement.
Interestingly enough, the handle seems to come apart. I am hoping we can disassemble the new handle and put my painted part from my original handle on the replacement one.
I guess we'll see.
Why wouldn't they be able to match the paint? There could be a TSB on it already. Maybe a software issue. It could be worse, try not to let the small things bug you....
Old May 11, 2020 | 11:39 AM
Todd in PA's Avatar
2020 S 560 4 Matic
deleted
Old May 11, 2020 | 11:58 AM
stever500's Avatar
2025 S63. 2022 911 Turbo S, 23 BMW M5C
I know... the quality of our problems. I'm sure they could have matched the paint perfectly though if no other solution was available. I obsess over my car too, but once this pandemic hit us hard, I started thinking... about everything differently. I have friends that can't even put food on the table right now since this pandemic shut down their businesses and they apparently were month to month paycheck people. I never even knew this.
The quality of our problems...
Old May 11, 2020 | 01:31 PM
Todd in PA's Avatar
2020 S 560 4 Matic
"The quality of our problems..."
OK, I give up, the internet won.
Old Jul 2, 2020 | 08:54 PM
Todd in PA's Avatar
2020 S 560 4 Matic
Public Service Announcement
In an effort to add to the information bank in the forum, I finally figured out why my keyless entry only worked intermittently. The dealer had screwed up ordering a new door handle, the passenger handle didn't fit the driver's door! Luckily for me, I read somewhere on the interweb that our keys go to sleep when not moving to prolong the battery life. I tried an experiment. If the unlock button didn't work, I jangled my key and the door unlocked when I touched the handle in the appropriate spot. I switched out the key I was using for my spare key and that key worked flawlessly. My door handle did not need to be replaced and I requested a new key. Hoping this new key will work the same.......
EDIT: To be clear, it was the key that was defective.
