S-Class (W222) 2014-2020
W222 Knock/Ticking Noise from Front Left when raising suspension/start-up
Old Aug 26, 2020 | 01:19 AM
jaggy22's Avatar
S450L
Exclamation W222 Knock/Ticking Noise from Front Left when raising suspension/start-up
I've got a 2019 S450 and have been hearing a ticking/knocking sound coming from the front left suspension every time I start the car up and the air suspension raises. It can be replicated by pressing the "raise" button as well. Brought it to two different dealers and they both said it is "normal" and happens to other similar cars with the Air Matic. Am just wondering if any one here has the same issue as well? It's not a very pleasant sound and is actually quite annoying so I doubt it could be a "normal" feature.
Thanks in advance!
Old Aug 26, 2020 | 08:16 AM
phillyreem's Avatar
GL450
Thanks in advance!
i have a 2020 and recently got out of 2017 S. I wouldn’t say knocking/ticking, but you can definitely hear the airmatic raise and release. Not sure I’ve ever heard a ticking noise though. Have the dealer pull out another out and duplicate it.
Old Aug 26, 2020 | 09:26 AM
jaggy22's Avatar
S450L
Thanks phillyreem, will ask them to demonstrate it tomorrow on another S.
Old Aug 26, 2020 | 03:02 PM
2012 merc amg's Avatar
2018 S560
I've had a few of these cars, sounds like something is not right, it is not a bad sound as you describe but more of a buzzing sound when the air compressor is running and then a click when it turns off.
Old Aug 26, 2020 | 10:57 PM
jaggy22's Avatar
S450L
Mine is light a "knock, knock, knock" sound as the suspension is raised. And when moving off slowly when cold it seems to be at a greater intensity. But it does not make any sound at speed or after driving for a couple of minutes.
Old May 3, 2023 | 12:32 AM
Horax's Avatar
eqe43AMG
Hi ! I have recently experienced the exact same problem.Have you identified what the issue is ?
Old May 3, 2023 | 12:34 AM
vinflouen's Avatar
2019 W222 S560 4Matic/2025 Yukon Denali
Maybe one of the bushings holding your compressor is bad.
That may explain the knock sound, the compressor vibrating metal to metal….
let us know.
Old May 15, 2024 | 06:36 AM
Theonlyomar's Avatar
W222
Thanks in advance!
Sorry for bringing this thread again to life. I had the same issue. Did you figured it out ??
Please update us if you do so.
Thnx.
Old Jan 22, 2025 | 07:40 AM
Robb92914's Avatar
S560, GLS63
Any update to this?
Old Jan 25, 2025 | 07:40 AM
vinflouen's Avatar
Its normal.
Old Jan 27, 2025 | 08:33 PM
Robb92914's Avatar
S560, GLS63
Mines in the shop now and as soon as they heard it they said it's not normal so we'll see what they say. Thanks!
Old Feb 20, 2025 | 12:51 AM
HEKI82's Avatar
Originally Posted by Robb92914
지금은 매장에 광산이 있는데, 그들이 그것을 듣자마자 정상이 아니라고 하니까 그들이 뭐라고 하는지 보겠습니다. 감사합니다!
Hello. This is a post you made a long time ago. Did you manage to resolve the issue?
Old Oct 31, 2025 | 11:06 PM
Vanquish59's Avatar
2019 S63 AMG (Current), 2015 E63S, 2008 E63, 2005 E55
Issue happening with my 2019 s63 sedan. Any update on this?
Old Nov 1, 2025 | 02:59 PM
carlosinseattle's Avatar
Top Answer: 1
2001 S600 V12 Sold, 2011 Jaguar XFR Sold, 2017 S550 4-Matic, 2018 S63 AMG Sedan
Is it on the side that got hit last year? Sounds like these mosty come from worn/broken suspension bushings. The only way to know for sure it to get the car up on a lift and look and feel what happens at the suspension and steering is moved back and forth. Lots of times, you only hear it when the car is still, but not when driving. Couple reasons. You might not hear it due to road noise when moving. But also, as force is applied to a suspension bushing in a particualr direction, it might not actually make any noise. Take it to a good indy shop or suspension shop, if there's one in your area. Normally; these things get progressively worse over time, so you'll know eventually. And also, look for uneven tire wear on that side of the car; is the inner, outer or middle, part of a tire showing weird wear patterns? That's the first thing a good mechanic will look for.
Old Nov 1, 2025 | 03:44 PM
Vanquish59's Avatar
nope, drivers side. There is a button to lift the car, its the airmatic. Its like a strong motor noise trying to lift the car up. Started happening 2 days ago.
