Broken/Help: Rear plastic seatbelt guide ring
I snapped this rear plastic seatbelt guide ring on my 17' S550e and I need two things:
- The part number so I can order a new one.
- How the heck do you fix this? The ring is closed solid. Do I disassemble the D ring that holds the seatbelt in picture 3?
https://www.ebay.com/itm/35332313497...KoHcV7j9uSyaYc
To replace the new part comes with covers that detaches right where your second picture is showing the metal pin (your existing loop does this too it just does not appear that way till you get the replacement part and see where it comes apart) and the plug that is in the car is surprising simple to remove by simply pushing DOWN and turn a quarter turn and it will release straight up/out.
When you get your new part you will see how the quarter turn to release works by looking at new part.
WITH THE NEW PART INSTALL IT IN THE SEAT BEFORE YOU RUN THE BELT IN THE LOOP. This will insure you install the part in correct orientation prior to putting belt loop together since its a ONE TIME assembly. When you remove the halves to your existing broken loop they are likely to break so thats why I say its a one time chance to assemble correctly.
If you have any other questions you can message me directly but I promise its a VERY simple repair. Only painful part is the 130 dollars for the new part.
PS I spent considerable time looking for a workable replacement for the broken part so as to reuse the original loop and I could NOT find anything with the correct color hence the 130 for a complete new part.
Ref:
I have a 2017 S550 Maybach and just broke this exact same part. I am terrible at finding parts online - any advice as to where I might find this part in chocolate brown? I am worried that A2228601022641B55 will be in the cream color, rather than brown. My dealer fed me a line and said they would need to replace the whole seatbelt assembly for over $1000 and wouldn’t give me the part number. Thanks!
how do I get it?
Belt Guide (the main loop part that plugs into the seat back) - A222-860-10-2264-8Q58
The two halves that lock the Belt Guide into a solid loop (otherwise it's incomplete and open-ended) - A222-868-07-2264-8Q54 and A222-868-08-2264-8Q54.
