S-Class (W222) 2014-2020
ABC pulsation dampener questions…
Old Jul 15, 2021 | 08:58 AM
Socalsteve's Avatar
2015 MBZ S 550
Hi all,
I took my 2015 550 with 35,xxx miles into the dealership for servicing and to see if they could figure out an intermittent whining-grinding noise coming from the drivers side front of the car. They diagnosed it as the pulsation dampener for the ABC system needs to be replaced at a cost of $725. I have a few questions:
1.) what is this part and what does it do?
2) Since it’s intermittent and does not appear to affect the car in any way ( save for an annoying noise on occasion), does this need to be replaced?
3.) if it does not get replaced, will it do any damage to the vehicle?
4.) Is $725, a fair price?
A few things, I drive this car maybe 2,000 miles a year, if that. Since it has such low miles and has been relatively trouble free, I am probably going to keep it for a few more years.
As always, thank you all in advance!
Steve
Old Jul 15, 2021 | 09:00 AM
Katie22's Avatar
18 AMG GTC and 22 F150 Limited. Past owner 16 Maybach, 17 Brabus Smartcar, 06 Ford E150, and 22 G70
What you are describing is the problem I had with my 16 Maybach. The intermittent grinding noise that got worse over time. For me it turned out to be the ABC pump. The repair was about 3000 dollars.
PS everything worked perfectly on my car it simply had that grinding noise that slowly over time got worse.
Old Jul 15, 2021 | 07:43 PM
Tom in Austin's Avatar
2019 S560, 2015 Honda Civic Hybrid
I'm still deeply confused about what "ABC" means exactly. I think it just refers to the standard Airmatic air suspension system that provides springing and raises and lowers the car's ride height. So ABC pumps, tubing, dampeners, etc. would be related to providing/delivering air to the four strut units.
I think what confuses me is people who say "Magic Body Control (MBC) is just ABC with additional software". I don't see how this could be true because MBC dynamically alters the suspension in response to road conditions using high-pressure hydraulic fluid. If I am correct, a system of hydraulic pumps and valves needed for MBC would be separate from air pumps and valves for ABC, making them two entirely different things. I know on my car, there is no evidence of any hydraulic hoses/connections to the struts. I also see when looking up suspension parts there are separate numbers for ABC and MBC cars.
If someone could clarify this, I'd really appreciate it.
Old Jul 15, 2021 | 07:52 PM
Socalsteve's Avatar
2015 MBZ S 550
My car has Magic Body Control. ABC is another way of saying MBC, just the newest version.
https://en.wikipedia.org/wiki/Active_Body_Control
In the end, the car dealership somehow got it covered under warranty, so that really made my day!!!
Old Jul 15, 2021 | 08:01 PM
Thanks for the Wiki link ... "Active Body Control, or ABC, is the Mercedes-Benz brand name used to describe hydraulic fully active suspension"
So ABC is a hydraulic system different from the standard non-hydraulic, non-active, Airmatic configuration. I just checked my car in the VIN decoder and it does not have an ABC code shown, and as mentioned in my previous post, I have not seen anything that looks like a hydraulic hose around the suspension. That said, like all W222s, it does have a "Sport/Comfort" button on the console, so this feature is apparently possible without an hydraulic, active suspension system.
Old Jul 15, 2021 | 08:15 PM
Baltistyle's Avatar
'13 s212 63 p30. '06 LX470
This depends on year and model (e,s,amg) so you will want to research the terms based on those parameters.
Mercedes has had hydraulic and air based adjustable suspensions for decades, many decades. The features of which vary between height adjustment to predetermination of a condition based on cameras, gps and memory.
The systems are pretty awesome and not hard to upkeep if you do the work yourself. Ive world onthe Mercedes and Lexus based systems as a diy person.
Old Jul 16, 2021 | 11:06 AM
Streamliner's Avatar
ABC or Active Body Control, was last used in an S Class, in the 2013 W221 models. Starting with the 2014 W222 S Class cars, a camera system was added to the ABC system and the option was called MBC or Magic Body Control. This option was available in the W222 for MY 2014 through 2020.
Old Jul 16, 2021 | 03:18 PM
Quadrobenz's Avatar
'94 SL600,'05 SL600,'06 S65,'07 E63,'14 E63S,'09SL600 all sold, ‘15 S65,‘18 E63S,'17 SL65, '17S65Cab
It is as Streamliner says with an additional caveat. Only rear wheel drive cars can have MBC. All wheel drive cars, such as the W222 S63 can only have Airmatic.
Old Jul 16, 2021 | 03:22 PM
roviw1's Avatar
2015 S500, 2016 GL63 AMG
I had the pulsation damper replaced under the used Mercedes warranty on my 2015 model s500. I think they said it would have been a little under £500 here if I was to have to pay for it.
My friend had his done on a 2007 cl600 which was how we figured what the occasional noise was, my car had covered maybe 45000 miles at the time.
On a separate point my car also has the very rare ( over here ) magic body control as well.
Old Aug 10, 2021 | 12:27 PM
konigstiger's Avatar
'71 Pinto
Replacement, see attachment.
File Type: pdf
