S-Class (W222) 2014-2020
Water drain plug
Old Oct 16, 2021 | 02:57 PM
604benz's Avatar
2015 S550V
Water drain plug
Hi Guys we have been getting alot of rain here in Vancouver, BC recently and i had my S class sitting in the driveway for a few days, i noticed when i opened my drivers door alot of water poured out, its not getting into the carpet or interior, is there a drain plug i need to clean, its only the drivers door it happens to, the other doors seem fine, if so can someone point out the location
Old Oct 16, 2021 | 03:22 PM
W205C43PFL's Avatar
Did you check the sunroof drain? Although someone else had issues with water on the driver side as well (but different vehicle), you did mention it is not getting into the carpet or interior so it is probably not it. Here is the thread anyways:
https://mbworld.org/forums/glc63s-gl...ers-floor.html
Can you tell us where exactly did the water get to, and what specific location has the most water?
Anyways, here are the drains you requested courtesy of forum member konigstiger:
https://mbworld.org/forums/s-class-w...ml#post8284693
Old Oct 16, 2021 | 04:09 PM
konigstiger's Avatar
'71 Pinto
Check lower door if none are readily seen try carefully removing cover strip ideally using plastic wedge to check (passenger side shown).
Old Oct 16, 2021 | 04:51 PM
604benz's Avatar
2015 S550V
Thanks for the info guys, luckily no water is going into the interior or carpet, the water seems to gather on the door sill and when door is open it pours out
