Battery Died...cannot get the car jumped now
battery....now I can't get it to start...the only thing that gets it juiced up enough is when I hook cables up to the jump points. No battery chargers I've tried have even come close to giving
me enough power to start it. Is there any kind of fuse or something I could check that might prevent me from starting her back up?
Thanks in advance!
Pete
If a battery is completely flat, a modern trickle charger may not charge it. It first tries to detect the correct polarity but cannot do it if the battery voltage is almost zero. An ancient charger would not have this issue.
Thanks in advance!
Pete
Nah, actually this is not true. My '16 S550 shows the "how to jump start" in the MB owners manual. Pretty basic procedure which is the same for most if not all cars.
Modern jumpstarters though are really idiot proof, and the Mercedes is super well laid out to where you really would have to try hard or be profoundly stupid to hurt it
Starting the source car helps the helped car battery gain a bit of power which is very good specifically if jumper cables are thin. Just connecting a good battery does not give much juice to the flat battery. It would be good to run the source car at least some time if not while starting the helped car.
Certain MB models had very sensitive SAM control units but jump starting with another car would be fine if done properly. I'd say best to have the source car switched off when connecting jump cables. Next start the source car and run it for a while. A matter of opinion if the source car needs to be switched off before the helped car is started but at least switch it off before disconnecting cables. Even better if the helped car too is switched off first. May not be possible if the helped car has a completely dead battery (not only low by charge but one that cannot hold any charge).
Its just not necessary or a good idea to jump another car off of one that isn't running.
In any case, the sourcing car battery is supposed to be able to start the sourcing car. If it was able to start the helped car and would die there, the helped car could be used to jump start the original helping car later on once it has sufficient battery charge.
Seriously, I would be much more concerned about the risk of a control unit failure rather than the risk that the jump start source car would not start if not running while providing help (actually not starting before the helped car gets jump started, but after the jump start cables have been connected).
Each to their own, it is only the owner of the car who can make the decision taking into account all aspects raised at this thread.
