19' s560 mouse infestation smell, how to get rid
thx!
thx!
However if there are dead mice, nest material and lots of you know what it may take a long time to return to acceptable.
Also, mice like to do bad things to cars, eg chewing wires, thus causing electrical system problems. You might want to ask an MB dealer to do a complete inspection.
The easiest way to remove any smell from a car is with an ozone generator, which are about a hundred bucks on Amazon. I have used ozone for decades and always recommend it for smells that are unable to be wiped away.buy at least a 10000ppm unit
They were also going into the engine air intake and hanging out under the air filter. No nest there but a mess with acorn parts and other debris. So I added some stainless steel mesh at the intake.
It took about a month for the odor to go away and so far no new signs. In the garage I have many ultrasonic things plugged in. Various makes and plugged into about every outlet - hopefully it’s an ultrasonic blast zone. I’ve added them to the house also. I think they’re working.
I installed one of these devices with ultrasonic noise & flashing light features, put in rechargeable AA lithium batteries. It has a sensor that shuts the unit off when car is on/moving, my S might get driven once every week or two, rechargeable lithium batteries last 3+ weeks. Since install, there hasn’t been any rodent issues. Work location is in the middle of NYC where rats roam the streets with impunity.
https://amzn.to/3Q9AtFf - Ultrasonic & Light unit x2
https://amzn.to/3Q9AtFf - Rechargeable Lithiums
If you want to personally tackle the cleaning, I recommend spraying hydrogen peroxide directly on surfaces and let soak for 10-15 min which breaks down the organic matter, bacteria, viruses etc., wipe and spray again with mild cleaning solution.
Spraying the carpeting down with hydrogen peroxide is color safe. Let it sit for 10-15 min, pat dry, give it a day or so to air out, when fully dry sprinkle liberal amounts of baking soda and let sit for 30-40 min, vacuum out and you’ll have a fresh interior.
